Sickle Bar Question about IH 1300 sickle bar mower
   / Question about IH 1300 sickle bar mower #1
meck
Ford 640
I just bought a IH 1300 mower and am going through it to see what needs renewing if anything. With the belt cover off, there is an idler pulley at the top run of the belt. Below it, on the lower run of the belt, is a "drive belt roller" according to the manual. Is this roller supposed to rotate? The one on here will not turn, and the way it is bolted on, it's not going to.
Thanks for any info. from someone familiar with this mower.
   / Question about IH 1300 sickle bar mower #2
Yes the “Rollers” should roll.
   / Question about IH 1300 sickle bar mower #3
These folks still make all the parts as their units are based on the original IH design. Mowers - Rowse Rakes
They can also service the heads and make a hydraulic lift system which I have on mine. Great folks - give them a call if you have questions. They have a complete parts manual on line too.
BTW - yes the roller should roll. there is a brass sleeve bearing that the bolt fits through with the outer roller. Mine has a grease nipple on it.
Hope this helps
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A55852)
2023 Chevrolet...
378467 (A51572)
378467 (A51572)
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
