Question about hydrualic flow on CK20S
   / Question about hydrualic flow on CK20S #1
Josh61513
Clio, MI
Hi all,
I am working on a log splitter project and would like to know how much hydraulic flow is available at the rear remotes of a CK20S? The tractor spec is "7.66 GPM total flow" but is it realistic to see that much flow at the remotes? I obviously wouldn't be using any other circuits at the same time. Does the tractor have one hydraulic pump or two?
Thanks,
Josh
   / Question about hydrualic flow on CK20S #2
Total pump flow is 7.66 GPMs. according to the specs. The PS pump develops something. Specs didn't say how much.
   / Question about hydrualic flow on CK20S #3
The CK20S is a single chamber pump. The power steering is controlled by a priority valve. Steering always takes priority when asked to. Otherwise, total pump flow is available at the remotes.
Excellent, thanks Bob!
Just out of curiosity, are all Kioti tractors arranged like this?
   / Question about hydrualic flow on CK20S #5
No, the CK20S is the only current KIOTI tractor with a single chamber pump / priority valve system. All others have tandem pumps, with one chamber dedicated to steering flow.
   / Question about hydrualic flow on CK20S #6
Thanks for the great info! How about my 2006 CK20HST, I believe they listed two different pump flow numbers for steering and hydraulics, is mine a "tandem" style pump?
   / Question about hydrualic flow on CK20S #7
The CK20 has a single chamber pump with a priority flow divider valve for the power steering, similar to the CK20S.
Priority flow to the steering system is 1.58gpm, on demand.
   / Question about hydrualic flow on CK20S #8
Thanks!
   / Question about hydrualic flow on CK20S #9
Should not have any problems with running a splitter. I have one hooked up to mine and works great, from northern tool.
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A56435)
Mahindra 4550-4L...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Dewalt 14" Chop Saw (A59076)
Dewalt 14" Chop...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
