Question about hydrualic flow on CK20S
   / Question about hydrualic flow on CK20S #1
Josh61513
Bronze Member
Clio, MI
Hi all,
I am working on a log splitter project and would like to know how much hydraulic flow is available at the rear remotes of a CK20S? The tractor spec is "7.66 GPM total flow" but is it realistic to see that much flow at the remotes? I obviously wouldn't be using any other circuits at the same time. Does the tractor have one hydraulic pump or two?
Thanks,
Josh
   / Question about hydrualic flow on CK20S #2
Total pump flow is 7.66 GPMs. according to the specs. The PS pump develops something. Specs didn't say how much.
   / Question about hydrualic flow on CK20S #3
The CK20S is a single chamber pump. The power steering is controlled by a priority valve. Steering always takes priority when asked to. Otherwise, total pump flow is available at the remotes.
Excellent, thanks Bob!
Just out of curiosity, are all Kioti tractors arranged like this?
   / Question about hydrualic flow on CK20S #5
No, the CK20S is the only current KIOTI tractor with a single chamber pump / priority valve system. All others have tandem pumps, with one chamber dedicated to steering flow.
   / Question about hydrualic flow on CK20S #6
Thanks for the great info! How about my 2006 CK20HST, I believe they listed two different pump flow numbers for steering and hydraulics, is mine a "tandem" style pump?
   / Question about hydrualic flow on CK20S #7
The CK20 has a single chamber pump with a priority flow divider valve for the power steering, similar to the CK20S.
Priority flow to the steering system is 1.58gpm, on demand.
   / Question about hydrualic flow on CK20S #8
Thanks!
   / Question about hydrualic flow on CK20S #9
Should not have any problems with running a splitter. I have one hooked up to mine and works great, from northern tool.
Horsch Joker RT32 Speed Disk (A50514)
Horsch Joker RT32...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2018 John Deere 460E Articulated Dump Truck (A52748)
2018 John Deere...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2024 Bintelli Activ-EV Pulse (A50324)
2024 Bintelli...
