Question About FEL Joystick
   / Question About FEL Joystick #1
Haneyrm
Water Valley, Tennessee
I am in the process of trying to buy a 2004 TC35DA with 16LA FEL. Most of the TC35's that I have seen have a pretty fancy looking joystick for the FEL that resembles something out of an F-16. The tractor I am looking at has the traditional "knob on a stick" look to it. It looks to be the factory set-up and I was wondering if the fancy joystick was an option or what. Thanks for the heads-up in advance.
Mike
   / Question About FEL Joystick #2
The non-deluxe(gear) version of the TC35 doesn't have the dandy stick, and there have been some complaints about the dandy stick breaking. The previous owner may have replaced the stick with the non-deluxe version. That would not be optimum if the tractor is a (D) or (DA), because the rabbit/turtle buttons are one of the best things about this tractor. Are you sure it is a DA?
Chris
   / Question About FEL Joystick #3
As Chris said, if the tractor has a hydrostatic transmission, it is a "DA" model. If it is a gear tractor, it is an "A" model. DA models also have a padded operator's platform.
The problem with the joystick should have been fixed by the 2004 model. What do the front lights look like? The 2004s should have had the new shaped lights.
If the tractor is an HST for sure, then someone replaced the factory joystick with the non-deluxe model. The Deluxe model is over $100, but less than $150 I believe. I replaced mine several years ago and I think the price was about $120 at the time. In my opinion, the joystick with the rabbit/turtle switches is worth the extra cost.
The tractor definately is the DA version. HST, padded operators platform, swivel seat, etc. The rabbit/turtle switch is not on the FEL joystick. It is on the panel next to the PTO and 3 point controls. Attached is a picture of the unit.
Mike
Is there any way to tell what year the tractor is by the serial number?
Mike
   / Question About FEL Joystick #6
Was that picture taken in Dickson, TN by chance?
   / Question About FEL Joystick #7
If you look on the NH website, you can see the two different types of joysticks.
Go to the parts and service, search on tc35da, select hydraulics, and look at the 2 function midmount remote. It has a picture of both sticks.
It is likely it was changed. I would spring for the dandy stick if I bought the tractor.
Chris
   / Question About FEL Joystick #8
Mike
There is no date code built into the serial number, but I can tell by the style of the tractor that it is at least late 2003 model or later. Sometimes you can find date stamps on fiberglass panels or on the inside of the rims (inside tire) where manufacturing dates are stamped or there is a sticker. I wouldn't really worry about it because that is certainly a later model "DA" tractor that looks very nice in your picture.
I'm including two pictures of the joystick. One is the new stick right out of the box and the other is it installed.
   / Question About FEL Joystick #9
Jim:
I have a TC40DA with a bush hog FEL. I went with that because it had a little more lift capacity to it. It does not have the rabbit switch to it. Can I change out the joy sticks with the NH Turtle/Rabbit switch. All I hear here is how you guys love it!
Thanks,
Wally
   / Question About FEL Joystick #10
602466 said:
Jim:
Thanks,
Wally
The NH joystick is standard on a "loader ready" tractor. However, since you have a Bush Hog FEL, it will depend on where the joystick is mounted. Is it on the right side of the operator's platform in front of the side console, or is it just to the right of the steering wheel, mounted on the loader post?
If the joystick is located near to the NH OEM location, I think you could replace the joystick with a rabbit/turtle one. The harness connection for the switch is probably there since it is a function of having the HST rather than having a FEL. You might talk to your dealer or look for the harness and connector yourself. You can see what the connector should look like by the connector shown on my joystick in the attachment in my last post.
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
