Question about Exmark setup
   / Question about Exmark setup #1
Zick
Platinum Member
WI
BX 2350
Does anyone know what this type of setup is that's on top of the front wheels?
VS this which I normally see?
Ah, your probably right cause I only seen that setup when it had the grass catcher on the back. I suppose that makes sense.
Thanks
   / Question about Exmark setup #3
Looks like cast weights as has been mentioned. It appears that they also have a set of weight plates under the middle of the mower. See the area outlined in orange in the picture below.
When I worked for a lawn care company, we had liquid cooled 60" and 72" exmarks. The 60" machines had weight plates in the front middle because the deck was not heavy enough to counterbalance the weight of the engine in the back.
Aaron Z
I've seen the plates under the middle of the mower before but I've just never seen weights directly over the top of the wheels.
   / Question about Exmark setup #5
Weight kits are standard when you get a grass catcher. I am very unhappy with the poor design of the catcher I have on my HUSTLER mower and the inadequate amount of weight provided. I do however like the mower.
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
