RollingsFarms
Veteran Member
- Joined
- Mar 26, 2007
- Messages
- 2,257
- Location
- South Carolina
- Tractor
- Few John Deere's and one Ford 3600 diesel.
the battery in my tractor died today, and a friend gave me a brand new Everstart Marine Battery. someone had used his boat one time and they bought a bettery to run the trolling motor with and just told him to keep it. its a 720 cranking amps(600 cold crankin amps). is this overkill for a 3 cyl. Yanmar John Deere diesel? i noticed that when i installed it and went to crank up the tractor, all i had to do was BARELY bump the key. the tractor itself seemed to run "differently", good different not bad different. the battery that was in the tractor before was a much smaller battery, yeat the battery box on the tractor could hold a larger battery then what i have in it now. i know it takes alot to crank a diesel, so would this Everstart Marine last awhile and do the job or should i go buy something else and stick in there? what minimum/maximum cranking amps should i get?
