Question about burn piles.
   / Question about burn piles. #1
krue
South Mississippi
MF 135 Perkins Gas
I'm piling up hardwoods (mostly pecan and cherry) that while they have been down for a year they aren't dead (half the stump still in the ground). How long after I cut and pile them before I burn them.
   / Question about burn piles. #3
Depends on how much brush you have to go with the logs. A good sized brush pile can be burned the same season once you get it started. The logs, even dry logs usually won't burn up in the first pile. I figure to burn my piles in the winter with snow on the ground to avoid fir problems then put everything that didn't burn into another new pile.
Starting a brush pile is easy with a leaf blower and diesel. I carry a bucket of split kindling and newspaper. Build my fire as far under the edge of the pile as I can get, Douse pile above it with diesel and light it off. Stand back with blower running at low speed and you will have a roaring fire in a hurry even with green brush.
I believe I got the 'blower' trick off of this forum.
Harry K
   / Question about burn piles. #4
Pecan and Cherry makes some really good smoke wood for cookers
If you have any Bar-B-Q joints or restaurants close by they may help you dispose of it
   / Question about burn piles. #5
There's no need to wait. A hot enough fire will burn dirt. You just need to get it going good before adding wet stuff. Green leafs will float away as you burn them so be careful.
   / Question about burn piles. #6
I've had fantastic results by cutting the trees into thirds. Somebody suggested that they dry out faster if the end grain is exposed, which makes sense. I've had piles of trees sit for over a year and they wouldn't burn, but when I cut them into third, even green, they burn right up!!!
It's also easier to take three trips to move smaller pieces of a tree than it is to struggle with the entire tree!!!
Have fun,
Eddie
   / Question about burn piles. #7
turnkey4099 said:
Starting a brush pile is easy with a leaf blower.....
Now that is a good idea. I struggled for 4 hours before I finally got a burn pile going last year. I know it would have been a lot easier using a leaf blower. At least I can use the trick for the other 5+ piles.
I agree with Highbeam that once the pile is going even fresh cut trees will burn.
   / Question about burn piles. #8
I use a cheap pump sprayer with disiel it acts like a flame thrower and you can get the middle of the pile going in a hurry. It smokes like he77 for the first 20 minutes but it will burn in a hurry.
I've been sectioning the trees up. Not a lot of brush, but I do have the treetops in the pile. The only brush is privet hedge and it doesn't burn worth a crap, I know I've cleared some serious privet hedge (which is why this time around is called project reclear ).
   / Question about burn piles. #10
Where I live, I have to get a burn permit. Pile can be no larger than 3 feet. RIGHT:D . And I can only burn after OCT 15. Now, my friends tell me these rules do not apply to cookout. They say they simply get some long sticks and some hot dogs, marshmellows and if the fire chief shows up, it is not a burn pile requiring a permit, but a fire started as part of a cook out, requiring no permit. It is all about the presence or absence of food. Wonder is this is true? I will call City hall.
Bob
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
LOT LOCATIONS (A52576)
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
