Question about 3pt on a BX23?
   / Question about 3pt on a BX23? #1
Bronco
I just purchsed a leftover BX23 yesterday:D Very exited to get it! Can I hook up a 3pt so I can use attachments like a post hole digger? Need to install 500ft of post fencing, could sure us a digger. I'm a newbie to this hole tractor thing and have alot to learn. Sure glad I found this site.
Thanks in advance for any info,
Bronco
   / Question about 3pt on a BX23? #2
The 3PH on the BX series is a "limited" category 1 hitch. That means it is compatible with standard cat.1 pins and spacing but has a limited lifting height. Obviously implement weight and size are somewhat limited as well. Just make sure you use implements specifically designed for subcompact tractors. There are post hole diggers available with shorter shafts made to fit the BX and other similar tractors.
   / Question about 3pt on a BX23? #3
Hey, thanks. I was wondering the same thing. Good to know. /forums/images/graemlins/smile.gif
   / Question about 3pt on a BX23? #4
You should have gotten a seperate carton/box with all of the three point equipment in it. I have one of these
web page
A little pricey but works excelent. Woods also makes an Estate Series specifically designed for the small tractors.
   / Question about 3pt on a BX23? #5
Congrats on your new machine! Even after 560 hrs, I'm still amazed at what it will do! Hard to imagine life without the backhoe. Many, if not most, of us BX owners use plain old Cat1 implements. Some of us with some specific implements have made minor modifications to accomodate them. I use a 48" and 42" auger on my BX.
Cheers!
   / Question about 3pt on a BX23? #7
Yep, you can dig many holes with the bx and a leinbach 7200jr. Mine has worked well for me
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2019 Nissan Versa Sedan (A50324)
2019 Nissan Versa...
Cub Lo-Boy 154 Tractor (A50515)
Cub Lo-Boy 154...
