Question about 3910 lift
   / Question about 3910 lift #1
Chancetribe
Ford 3910
It seems like my lift arms do not go very high. Also, the lift only raises all of the way and lowers all of the way with very little movement of the lift lever. Less than 1 inch movement on the lever moves the arms completely from all the way down to all of the way up. Is this normal?
Jeremy
   / Question about 3910 lift #2
Is that with no load? If so, put a load on it and come back with the results.....No it's not like the one I just bought and I would answer not normal. Mine has a fabulous 3000# lift, great flow for fast lifting and with the extra long lift arms, lift pins are about even with the back of the seat top. Goes from all the way down on an implement resting on the ground to all the way up, at IDLE, cold...just turned on in idle, in about 3 seconds, implement being a HD 7' disc harrow with 270# of Ford rear wheel weights resting on it.
Had a thought and jumped out of bed to get it down before I forgot.
You didn't say how familiar you are with your tractor or anything else for clues. To the right of the seat and a few inches below are 2 levers. The outside one you know about as you are trying to use it.....Position Control.
The inside one is the Draft Control lever and it's purpose is to allow you to plow at a steady depth and speed when the terrain changes. When plowing you adjust it for smoothest response from soil variations in combination with the Position Control.
However, when only using the 3 pt Lift function, the Draft Control lever needs to be all the way down. If it's not, you can get screwy results from trying to operate the Position Control such as you describe.
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
