Ques Re Hrs Interval on Changing Hyd Fluid
   / Ques Re Hrs Interval on Changing Hyd Fluid #1
plaindriver
Crossville, Tn
JD 750 4WD, Kubota L4600DT
I bought a new compact Kubota, L4600 4-wd tractor, with shuttle shift. Has a 6' wide bucket in front, and I often use forks. The unit has been seemingly bulletroof. I just use it around our little 5 ac spread. Im retired, unit never leaves the property. The tractor now has 230 hrs on it. The front end loader seems to have slowed somewhat since new. Have never chg the hyd fluid, but there are no leaks.
Could the slower lift action be due to "tired" or worn hyd fluid?
Thanks in advance.
   / Ques Re Hrs Interval on Changing Hyd Fluid #2
Tired or worn fluid probably not the problem. Maybe a partially clogged filter.
   / Ques Re Hrs Interval on Changing Hyd Fluid #3
I'll agree with the partially clogged filter - or even internally collapsed. Be sure your three point control is not set all the way to up. That can slow hydraulic response. Check your fluid level.
   / Ques Re Hrs Interval on Changing Hyd Fluid #4
Have you done the required service per the manual?I would bet plugged filter also.I also had a problem with the three point hitch out of adjustment and putting the hydraulics into releif(have dealer adjust).
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
STORAGE FEES (A51222)
