Tiller Query tiller rotational speeds
   / Query tiller rotational speeds #1
qni51
NORTHWEST UPSTATE SC
JD 2305
Can anyone tell me the Hi and Low speed range of tiller blades?
   / Query tiller rotational speeds #2
Are you asking about 3pt hitch or walk behind?
For my 3pt hitch Woods tiller I'm not sure. I just set my PTO speed to 540, drop it in and let it rip :D
3 PTH model.....
Considering taking the engine off of the 5 hp (1/2 a) 3pth tiller for my SS18 Sears and putting on a PTO to gear box, to V belt drive. No sense
in running a gasoline engine and the diesel JD 2305 engine both. Tiller width a bit narrow but will be better than nothing or a spring tooth cultivator.
   / Query tiller rotational speeds #4
The 540 PTO rpm is reduced to 200-240 tiller shaft rpm depending on model.
jb
   / Query tiller rotational speeds #6
KingKutter II tillers turn 210rpm @ 540 on the pto.
   / Query tiller rotational speeds #8
Thanks from me, too.
Exactly the info I was looking for -- Doing an Electric Motor driven Roto-Tiller, and looking to determine drive ratios to get the Tiller Rotation Speeds correct.
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
43011 (A51691)
43011 (A51691)
2005 Sterling Acterra Tender Truck (A52748)
2005 Sterling...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2012 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A52141)
2012 VOLVO VNL...
