Quantum Fireball HDD's aptly named
/ Quantum Fireball HDD's aptly named #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Quantum Fireball HDD\'s aptly named
Well. had one of the HDD's go south on my wifes computer this weekend.
I was in the middle of updating virus deffs from symantec and computer hung... reboot showed the dreaded primary master/slave controller failure. ( master was an older 1996 1.6gig WD, slave was a newish 2001 10gig QFB .. secondary controller had a Cd and CDR on it.. and was unaffected ).
My first thought was that the older WD had given up the ghost as i heard a good amount of racket coming from the HDD bays when powering up.
I guess I shouldn't have been surprised to find it was the newer QFB. So far, in my computer experience.. I've only ever seen one western digital drive die*.. and it was an old type 17 ( 40 meg) drive back in the old 286 days, and it was on a friend's clients' computer. ( Only one IDE that is ). I've personally had an older 140meg conner HDD die, but only after I had used it for years, retired it, and then loaned it to a friend to use in his 486. It ran there for over a year and died.. course.. he moved quite often.. so the drive got to see lots of 'action'. The QFB 5 1/4" footprint in one of my home computers ( old pentium 3 - 400mhz system ) Has hung and not re-nooted immediatly a few times, though ( knock on wood ) is still spinning. ).
I've never had a maxtor, or seagate drive die onme either.. but then.. I try to use mostly WD drives.
I generally refurbish my old computers and send them to school with my wife. She sets up computer workstations in her class ( elementary and middle school ) and lets the kids run educational games on them. So far I've got about 4 boxes setting in her class right now. All are using older hdd's This last one I just built has an AMD k6-266 processor, a wd 1080 meg drive, a maxtor 340 meg drive, and a WD 202meg drive, plus a cdrom. The 1080 meg drive was in the system when I put it together.. the two other smaller drives I had setting in external drive enclosures ( H45 ) and were running them on parallel ports. That's old news now with USB drives.,. etc.
I think my oldest system in her room was an old 486 that I dropped in the pentium 83 overdrive chip. bus acrchitecture is VESA/local bus, and I believe it has 24 megs of 30-pin simm memory in simm stacker cards, as that old board only had 4 simm slots. It is also running some vintage HDD's a maxtor 540 from about 93 and another older WD that I had laying around unused from an upgrade to my old dial in style BBS.. also early to mid 90's.
Guess whatever supplier that is making the quantum drives.. um.. needs some help...
Wow.. this is almost getting nostalgic. I'm thinking back to the old days of hardware mods for speed.. and trying to stretch the limits on things. overcrystalling, and later, overclocking.
Also.. old MFM and RLL drives. And those neat perstore controllers.. double the drive space.. half the HDD life!
serial networks.. arcnet network cards (I liked thomas conrad cards.. etc ).. go back farther to the baby box computers like comedore, and color computers.. and slant4 trs-80 etc and there were tons of mods you could do.. stereo SID chips.. ram and serial packs. 1mhz patch for the commie 64.. etc
Just for fun me and frineds would find old salvage computer parts and try to interface them to different systems. I remember an old NEC laptop I had.. v-30 processor.. and it had an external drive controller.. we found and hooked up a dual 8" floppy. Used driveparm from old MS-DOS to make it work..
I remember when we moved the BBS system onto my shiny new 286-16.. we bought a 'large' ide drive for it... and the bios on the 286 wouldn't support it. had to get an add on ide host card with bios. You had to use debug to program in the drive paramaters for the card... neat stuff..
Early SCSI and ESDI stuff was neat too. I remeber when media was so expensive that refurbed media was a big seller. We picked up a few fujitsu 3+ gig drives ( big money back then.. even for refurbed media ).. took all night to format those drives.. and the adaptec card was a full lenght card.. don't see much scsi stuff any more. Someone gave me one back inthe 486 pre-win 3.x days. I had it running on an 8 bit card. Used it as extra storage. I tried it on one of those SB-16 cards that had a scsi port on it.. but the drivers never worked under dos. when win-3.x came out I thought it was fairly neat that windows automaticall picked up on the embedded scsi controller in the sb card. Drive was swapped over to it fo an immediate performance increase.
Serial stuff was just as fun. Nothing had 16550 uarts on it, and they were hard to find. 16450's with defective fifo buffers were a big buzkill.. and really no better than 8250's. I can rememebr desoldering lots of 16450's and socketing cards for 16550 uarts.. got fairly good at it.
I think the strangeist thing we ever cobbled was an older computer system ( tandy r series ) that only had one expansion port .. it was a 16 bit port, but use a weird riser card that let you install 3 cards into it, by turning them sideways. Course it only accomodated tandy half heigth half length cards. We took an old card.. literall hacksawed off the bottom pin edge connector, and made a jumper with ribbon cable.. and soldered it on the the pin edge. Then we gutted an old mainboard for its card slot section.. again.. hacksaw in action. soldered the ribbon cable onto the backplain and was way surprised to find that it worked. Those 4 or 5 extra cards sat uncerimoniously in a shoebox next to the computer...
well.. gotta get to work and stop 'remembering'....
oh yeah.. back to the point... QFB drives just fell a few notches in my book...
Soundguy
/ Quantum Fireball HDD's aptly named #2
Re: Quantum Fireball HDD\'s aptly named
What? No comments about putting together S100/CPM v1.4 systems back when a 64mb memory card cost $750. I am beginning to think we have been around too long.
I am glad to see you have an outlet to put old computer stuff to work. All I can find to do with my old stuff is recycle it about once a year when someone will accept it.
Vernon
/ Quantum Fireball HDD's aptly named #3
We lose probably 12 WDs a year, on average, out of several hundred devices. They are on 24/7/365 with power savings turned off and they seem to run and run, but they do fail occasionally. Usually well past the 3 year warranty period. Very good track record compared to the other brands. We try to use them as often as possible. There are never any hassles on any that fail within the warranty period. Just get an RMA, ship 'em in and we get a new one. Very good company to deal with.
/ Quantum Fireball HDD's aptly named #4
I had an old Packard Bell 486 that I put a WD 1.6 GB in. It lasted about a month and started getting bad sectors. WD said they had some issues with some of the 1.6 GB and sent me a new one. Same thing happened to it, about a month later. I called them back and they replaced it with a 2.1 GB at no extra charge. Problem solved.
/ Quantum Fireball HDD's aptly named #5
Soundguy,
You are right WD drives are best. Of course the first HD I worked on was an HP rackmounted one. About a 12 inch platter and held a whole megabyte of data. Wow leading edge stuff. And cost about 10K.
Ben
I'll reply enmasse here:
Texbaylea:
Oh yeah.. CPM.. gotta love it... Makes you wonder why ms-dos went over so well, since cpm was such a similar CLI.
Mossroad:
I actually think the running 24/7/365 is a bit easier on the machinese than the start/stop cycles.
I still run 1 node of a dial in bulletin board system. The system is a ( get this ) AMD 486DX 40, overclocked to 50 ( processor ain't terribly fast at 50 mhz.. but the bus was.. I remember a budy that had a 486dx4 100 ( 25mhz bus ) and we used the whetstone clocker, and for sheir processor speed, he beat me by a few points.. but bus work, like dma and data transfers, it competed very well. Has a couple of wd 1080 meg drives, and 2 scsi 4-cd towers.. 24 megs ram, a serial card with hand soldered 16550 uarts, and a bunch of other hodge podge equipment...including an old VLB 24 bit windows accelerator card... (win3.x / workgroups/win32 ).
As for easy of WD.. I think one of the best things is the jumper selection. As far back as the 100mb and up drives, they have had the easiest jumper selection.. either master or slave.. and on the newer drives.. also cable select. Even the seagate and maxtor drives were a bit more involved with what you needed to jumper or unjumper to get the drives in correctly.
Slowrev:
Talk about old hardware.. reminds me of the winchester hdd's
Speaking of old HDD.. I guess most people these days don't remember when you could buy a hard drive, and printed on the outside label of the drive was the defect manifest showing what head/cyl/sec # a defect appeared.. even though it was mapped out, or swapped with sectors from the engineering cylinder. Loved that old stuff..
Soundguy
/ Quantum Fireball HDD's aptly named #7
Wow Soundguy,
This is some old stuff you're talking about. People used to giggle at me talking about the old Tandys and Ataris.
I sometimes get a kick out of taking out the Popular Science magazines [late 70's - early 80's] and see just how far we've come.
Some of those old hard drives were way over engineered. I have an old Seagate 100Mb drive that a buddy gave me, the darn thing runs silent. You really have to listen to hear it reading or writing, and just sittin there spinning, you can't.
You know, we've absolutely spoiled our children with technology, (for example, they've never had to use a slide rule to analyze electronic circuits.)
phil
/ Quantum Fireball HDD's aptly named #8
I had a buddy that had a Tandy. I remember when he got a whopping huge hard drive (must have been a whole 5mb). Couldnt fit it in the machine so he built a little mdf case for it.
I remeber my Father bringing home the Four Color monitor, WOW was that cool. I was hooked on four color Kings Quest (I think that is it).
I barely remember my brothers playing Zork I when I was younger ona z80 terminal that we had in the basement.
I've seen drives crash, but I also have a stack of Maxtor and Seagate in my closet that start around 250mb and go up from there. They still work so I wont through them out. I alway say I am going to get that old 286 back up and running so I can use some of these old 5.25" games........ (but then I dont use the ones I have now...)
Yep.. every time I find an old drive i had.. I go search it to see what I was doing then. The last two small ones I found were from my 286 and 386 days. I found a text based dnd game on the 286 drive...
Soundguy
/ Quantum Fireball HDD's aptly named #10
Matthew, my first hard drive was a "reconditioned" 5mb from Radio Shack that cost me $300 and it died just after the one year warranty ran out. /forums/images/graemlins/frown.gif But at least it came in its own case; not much bigger than most desktop computers now. /forums/images/graemlins/laugh.gif
/ Quantum Fireball HDD's aptly named #11
Personally, and I have a lot of experience here, I don't think any of the modern hard drives are that great.
In the past 5 years I've lost 2 Hitachi (IBM) Deskstars, and 2 WDs.
I just go for the cheapest drive now, I don't think any are much better than the other, and how long yours lasts is merely the luck of the draw. The IBMs were high-dollar drives, the only good thing about them is that they failed so early in their life that I got warranty replacements.
Leaving your computer on all the time might help some /forums/images/graemlins/smile.gif
My computer in my office and home office does run 24/7/365.. and yes.. it is easier on them. start cycles are the hard part.
Soundguy
Wow.. that is a shocker! I know some other manufacturers have sold re-manufactured goods.. but then marked them as such too.
I'm kind of surprised that the wd-auto install tool didn't make short work of their data when it did a low level prep. Their low level prep must not change the partition info, or really low level format the drive.. just refresh some of the info in the engineering cylinder.. etc.
Guess if their auto install tool had formatted the drive you would never have found out about this.. weird.
So far I've always had my best luck with them, and have never seen a modern one die.. liek I say.. last wd I saw dead was a type 17 ( 40 meg drive) and that was a bazillion years ago. Fujitsu was a big seller of used media.. not sure what happened to them or any of the other #3 name players inthe media business. I remember there was a company.. Kalok.. they had drives very similar to seagate. etc.
Makes ya wonder about any kind of media that goes into the trash. After all, even a hdd that suffered a head crash can usually have most of the data retrieved by dropping the platters into new housings. There's big money in data retrieval services inthe corporate world...
Soundguy
UNUSED IRMC HIGH-END MASSAGE CHAIR (A64281)
UNUSED IRMC...
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
Dodge 5500 Bucket Truck (A63688)
Dodge 5500 Bucket...
Caterpillar 988B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 988B...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
Caterpillar Engine Parts and Service Manuals (A63117)
Caterpillar Engine...
