Quality Hydraulic Disconnects
   / Quality Hydraulic Disconnects
These have been on now through the first cutting of hay and worked well so far. No leaks to speak of, just the normal little loss when Make / Break the connection.
Stucchi IRS PC
I ought to just call you guys. I'm back at it trying to figure out is the 7241 or poppet style in 1/2" body will plug into a Stucchi poppet style female. SafeWay's S71 in poppet or ball type males will plug into all their 5675 female couplers.
I am trying to fix an old Bobcat with what look like 7241 1/2" with a poppet style male on one side. I'd like to make it 5675 standard and don't know if I need to replace the 1/2" 7241. Guess I could just by a set of 5675 males in poppet and ball style and try them but there should be an easy answer without doing all that.
Update on Couplers. Stucchi IRS PC are as big a leaking mess as any of the others.
I'm going to break down and try a set of Faster 4SRPV, push / pull, break away, connect under pressure type for one tractor.
The Fasters on the loader have not leaked a drop in the last 8 years. That seems to be a pretty good recommendation.
I'll give the Pimaks to someone I don't like and keep the Stucchis for spares.
2017 CHEVROLET 2500 HD (A50854)
2017 CHEVROLET...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2022 ISUZU NQR 18FT FLATBED (A51222)
2022 ISUZU NQR...
2005 Kawasaki KAF620E Mule 3010 4x4 Utility Cart (A49461)
2005 Kawasaki...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
