QC adapter?
/ QC adapter? #1
BufordBoone
Platinum Member
Tuscaloosa, Al
Kubota L5740 & M7060
My L5740 has front hydraulic third function connections. For whatever reason, the ones the dealer installed are: HNV12NPT, Part 75568-66320 F, 75568-66220 M.
For compatibility (my 4-1 bucket and grapple are both equipped with the same connectors), I had them put on the M7060 we got last spring.
I first realized they were not the standard "Pioneer" connections when my neighbor offered to let me use his grapple a few years ago. What I'm calling "Pioneer" connections are the same type used on my rear remotes.
He now has a Limb Ninja that he is offering to let me use.
I'm thinking I could either 1 - swap quick connects when using it or 2 - make an adapter.
Any reason why I shouldn't get another set of the QCs I'm currently running, a set of the pioneer QC and a short piece of pipe and make an adapter?
Thanks!
/ QC adapter? #4
Not a comment on you connections, just a reminder. When you use your neighbor's hyd. equipment you're mixing what ever brand/grade of hyd. oil you use with what he uses. I'd be cautious about what you end up with in your hyd. tank.
/ QC adapter?
Great reminder, D2Cat. Certainly appreciated.
I did think about that. We both have Kubota M7060 tractors. When I got mine, he told me "Use the Kubota fluid. It may cost more but is a small price to pay to ensure you don't mess up your system. Also can't be an issue if you have a warranty claim".
Based on the above, I think I'll be fine.
Again, though, I appreciate the thought.
Unused 2022 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2022 Ideal...
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
PORTER CABLE AIR COMPRESSOR (A67714)
PORTER CABLE AIR...
2012 FREIGHTLINER M2 6X4 T/A ROLLOFF TRUCK (A66091)
2012 FREIGHTLINER...
3142 (A63117)
3142 (A63117)
