QA Hay spear
/ QA Hay spear #1
BlackDogTx
Waller, Texas
LS G3038H, Kawasaki Mule 3010 Trans Diesel
Hi does anybody have any recommendations or sources for a Quick Attach hay spear for my G3038H?
Thanks,
BlackDogTX
/ QA Hay spear #2
/ QA Hay spear #3
Also note: as with many QA attachments, you may need to adjust the attachment point openings to engage with the LS latches better. (I have to do mine yet)
/ QA Hay spear #4
I bought this one - Hay Spear Attachment Quick Tach style | Hay Spear Attachments | Hay Spear Attachment Quick Tach Style | palletforks.comm
It can double as a fork attachment, and I already had fork blades for it :)
FYI - you may struggle carrying round bales around with the 3038. I know my R3039 struggles carrying them using the bucket, and it has 350# greater lift capacity. I have yet to move one with the spear though...
Have you thought about carrying the bales on a three point hitch mounted spear? Just a thought.
/ QA Hay spear #5
Yes, but while that works for carrying, it doesnt always for loading/unloading from a trailer.
/ QA Hay spear
Yep.. I am planning on moving the smaller rolls no bigger than 4 by 5's.. I will check 'em out.. Thanks!
/ QA Hay spear
Bingo Mangus, gotta get em off the lowboy.. :)
/ QA Hay spear #8
Small Farm Innovations Caldwell TX 979 200 0766, $440 used mine to pick up a Hegar RB to the top
/ QA Hay spear
Hey Neighbor! I will check them out in Caldwell as I need to stock in some rb's for the fall and winter pretty soon.
/ QA Hay spear #10
Hey Neighbor! Got my 5030 at Small Farm Innovations nice people willing to work with us. Where you getting your RB's?
/ QA Hay spear
Hi! Where is small farm innovations at? I bought my G3038H from RCO in Austin, and man, I love my LS. Huge improvement over my old 80's model Kubota... They were great to deal with also for sure!.
I am still looking for somebody close to buy my bales from for the winter. Do you have any suggestions for clean Horse quality bales that aren't super huge??
..Eric
/ QA Hay spear
Just looked them up. Duh, they are in Caldwell where you got the hay spear. First cup of coffeee still..
/ QA Hay spear #13
I always use Hegar Hay he is less than 2 miles and always good hay he will have some barn kept RB'S, not too heavy
/ QA Hay spear
Hey that's pretty close. I will check them out.
Thanks!!
/ QA Hay spear
So I finally got the Hay Spear. QA from Titan Attachments off eBay.. Arrived quick, installed easy with the QA. $375 free shipping. Awesome!!
/ QA Hay spear #16
How well do the QA pins lock in? So far everything I have bought from Titan has larger QA holes, and there is about 1/4" slop on the pins. Easy to fix, just wondering if its my tractor!
Also - what made you choose that one vs the model that accepted pallet forks too? just curious....
/ QA Hay spear
Hi,
It fits up pretty tight on mine.. Does not appear to have a lot of play in it. I chose that one as I don't really move much around that would need pallet forks, but then again, never really thought about it.. Mostly need hay bales moved.. I can't move much bigger bales than the ones in the picture (tractor limitation, not Hay Spear's), but for my purposes, works fine.. Well unless I talk my wife into a larger LS in a couple of years..
..E
/ QA Hay spear #18
Where is the limitation? Hydraulics? or Balance weight?
My R3039 gets a bit light in the rear end when moving bales....
/ QA Hay spear
Hydraulics. I tried to lift one off my trailer the other day during a rainy week and I could not lift it high enough as it was a soaked bale (same size bale dry, no problem to lift). I rolled it off the trailer by hand and then was able to lift it enough with the tractor to move it where I needed it.. Mine definitely gets a bit light in the rear also, which is why I left on my 6' shredder for a bit more ballast..
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
Bobcat SC72 (A64127)
2022 EZ-GO ELITE...
