QA Bucket Rollback Angle Increaser???
/ QA Bucket Rollback Angle Increaser??? #61
It is your tractor.
civesnedfield said:
It is a steep uphill battle.
Yes... literally and figuratively both!!! :mad:
Dougster
kevinj said:
That looks like my tractor!!!!!!!!!:D
OPPS!!! :eek: Caught again!!! :D
That's twice in two days! :)
Dougster
/ QA Bucket Rollback Angle Increaser??? #64
Dougster said:
Original spec is 20 degrees. I think I was overly generous with my 11 to 13 degrees gain... so let's say I gain 10 degrees for the sake of conversation. That's 30 degrees and yes... you are right... that puts me in the ball park of where a lot of folks are who have those compound linkage arrangements. Maybe my other problem is more at fault here... just a 15 inch deep bucket. Even at 30 degrees of rollback on my 78 inch bucket, that's only about 2.54 cubic feet of "water holding" capacity compared to 1.74 cubic feet at 20 degrees. Better, but still not very impressive.
Dougster
Man, 46% increase and your still not happy. That 7520 is looking real good about now.:D Of course, it would need the extra roll back linkage also,:p part #?(available)
Oh Brother!!! Always the 7520 trouble makers have to show up! ;)
If I had a 7-foot wide 25" deep bucket... 12,000 lbs and 75 HP... I wouldn't care a hoot about the rollback angle... but note, by the way, that you've already got 29 degrees to my 20!!! :eek:
Life isn't fair. :rolleyes:
Dougster
/ QA Bucket Rollback Angle Increaser??? #68
pekabu said:
What about changing your quick attach out. Coastal tractor in CT is selling these adjustable quick attach's that seem like they would have a lot more rollback for under $400.
eBay: Adaptor plate for Tractor loader backhoe Skid steer (item 130119454738 end time May-31-07 15:39:38 PDT)
Wow!!! Is that close to perfect or what!!! :) Well done Dave!!! :)
The new angle... plane of pins vs. attachment face... is perfect! The only drawback is that it appears this particular unit would lift the bucket a bit too high (relative to the pivot pins) for effective "scouping" at or near the maximum rollback angle. Still, I am impressed and encouraged that such a device exists and could be used on my own FEL. I'll definitely check it out next time I am down at Coastal! :D
Dave, you get the prize!!! ;)
Dougster
/ QA Bucket Rollback Angle Increaser??? #70
Let me know how it looks. I am interested in it for my non qa tractor.
/ QA Bucket Rollback Angle Increaser??? #72
Dougster said:
If anyone has seen or bought one of these lately, please PM me.
Thanks! :)
Dougster
Id love to have something like this, but it looks as tho theres a serious downside. In comparing to the dimension dedicated SK on my 7520 it appears that the adjustable one setsthe bucket 3 inches or so further forward. :( This is good only if you want it. It can be a serious limitation to max lift load and tractor stability. I think Ill look into a dedicated one for the Woods FEL on my wifes L3450.
larry
larry
Hi Larry - At this point, I'm more concerned about continuing "dropped bucket" problems with my ML112's QA tool carrier. I just can't seem to get it to work properly. If this thing is really heavy-duty, it may be worth the $495 (which includes their shipping) plus CT sales tax they want for it down at Coastal Tractor.
One way or another, I've got to stop dropping buckets. :eek:
Dougster
/ QA Bucket Rollback Angle Increaser??? #74
I just looked at the specs for mine and its 30 degrees roll back on ground? looks like less though but I never measured it
Case can't be wrong :D
I'd be much happier with 30 degrees. My FEL bucket rollback spec is only 20 degrees... and with just a 15" deep buckets, it makes picking up material close to ground level a rather frustrating chore. :eek:
But at this point, I am far more concerned with the strength of my current tool carrier (or lack thereof) and whether this $495 device would be stronger and give a better fit for my QA attachments. Put another way: Would this device solve my embarrassing "dropped buckets" issue? :confused:
Dougster
/ QA Bucket Rollback Angle Increaser??? #76
Dougster
Doug, that sounds like a KMW problem. I would think they wouldve addressed it by now. Mine is good - and I do 90 degree back drags with loaded fronts. It looks as tho Ill finally have to strengthen the pin slot ears on the bottom of the bucket however. The rt one has deflected a little. Are you having the problem with a KMW bucket??
larry
/ QA Bucket Rollback Angle Increaser??? #77
Doug, don't forget to add about $200 for shipping for this item and it looks like it may put your load further in front decreasing your lift capability
larry
I am having trouble with every bucket I own (two of three are KMW) plus my root/rock grapple. I'll be trying it on my new CAT toothed digging bucket on Friday.
Three grapple drops today in front of the client. :( One almost snapped the hydraulic lines. :eek: I am so sick of it, it hurts. :rolleyes:
Dougster
The $495 price is picked up at Coastal Tractor in CT. Shipping to them is already included in the $495. I will have to pay sales tax. That being said, I've just been told of a possible lower price through someone else. :cool:
Lift is already a problem... but that is related to my tractor hydraulics I think. I'm starting to think my operating pressure is set way low.
Dougster
/ QA Bucket Rollback Angle Increaser??? #80
Dougster
What does KMW say about this. Is KMWs SK attach for the 4110 unfit for use, or is yours damaged?!
larry
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
4 INCH TOWABLE FLUID PUMP (A67714)
4 INCH TOWABLE...
2005 PETERBILT 379 (INOPERABLE) (A67714)
2005 PETERBILT 379...
2023 CATERPILLAR 289D3 SKID STEER (A65056)
2023 CATERPILLAR...
BOBCAT 435AG (A68134)
