QA and LM bucket for b2620
   / QA and LM bucket for b2620 #1
bstrom
Platinum Member
Maine
kubota b2620
Decided to follow ChuckinNH's example and got the QA for my B2620. Also got the Light materials bucket for moving snow, mulch, woodchips, firewood etc. Will use my 50 inch bucket for the heavy stuff, gravel, rocks, dirt. Saving up for the forks next! Ready to speed up my snow removal and pile up now.
   / QA and LM bucket for b2620 #2
just curios what you paid for the bucket. I have the 60" Lm bucket now and would like to have a smaller bucket with teeth as well.
Rob
Rob
Here in Maine I paid $559 for that 60 inch bucket. There is a 54 and a 50 also which are are probably somewhat less. I have the 50 which came with the 2620 and a toothbar on it. The QA was 279.00. Saves time and mess changing buckets or to forks and doesn't weigh to much.
   / QA and LM bucket for b2620 #4
Looks good on there! Did you get tired of screwing those little nuts on the extra long bolts? :D I might just have to do that too. It looks like a much better set up for snow than the OEM bucket.
   / QA and LM bucket for b2620 #5
Kubota doesn't offer the QA as an option on the Bxx20 series...but I hearing it is compatable with the LA364 Loader. Is the Non-QA Bucket that came with your tractor compatable with the QA or do you need to alter it?
Thanks in advance for your response.
Chuck - Yeah, I think it's gonna be better for moving snow around my crazy driveway set up than the smaller bucket. I think it holds half again as much. The plow truck is just about useless in front of the garage and a shed I have as well. Run out of room real quick without piling it up. Guess a blower really needed but would blow my budget and I want to get the forks like you have.
Yeah, no problem with the OEM (50 inch) bucket fitting the QA. The LA364 seems rugged enough to handle the QA and larger bucket too, I had it about 3/4 full of gravel last nite without a problem although I wouldn't make a habit of moving heavy materials with it and I'm sure Kubota might disapprove. I had my ballast box on the back and didn't get it up to high.
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
Ih 490 Disk (A50514)
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
