PX9020 Clutch Adjustment
/ PX9020 Clutch Adjustment #1
dimon1980
mahindra mforce 105P
Hi folks,
Did not find it here, and decided to ask. Can someone help with the clutch adjustment for PX9020...manual says "see dealer" and it is not possible, since dealer is really far away:)
Maybe someone did the adjustment of the clutch...basically, tractor is not moving till the very end of pedal move, and if I do not use clutch, and just push the lever forward, it sitting there for few seconds and then jumps roughly.
/ PX9020 Clutch Adjustment #2
I probably can't help you much with this issue, but it might help if you provide a few details about your tractor. Like what transmission option it has. Dry clutch, power shuttle, cab, no cab, etc.
It looks like dry clutch cab tractors have a hydraulic clutch pedal system. As in a master cylinder and slave cylinder. Probably not a lot of adjustment there, but again, I really don't know that tractor.
Check your PM inbox
Harry, it is tractor with a cab. Power shuttle. I think it is "Multi Wet Disc Clutch"
/ PX9020 Clutch Adjustment #4
Sounds like you need more information than I can supply. I would say the clutch pedal switches may need attention and/or adjustments. Probably the shuttle packs need calibration. That's just a guess based on experience with that TYPE of system, not necessarily yours. That would explain why they refer you to the dealer, as it's usually more involved than most users are equipped for.
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A59905)
2005 INTERNATIONAL...
BUNDLE OF 8'-13' CORRUGATED METAL SHEETS (A60432)
BUNDLE OF 8'-13'...
2020 Ford F-250 Ext. Cab Service Truck (A59230)
2020 Ford F-250...
7079CFL (A59228)
7079CFL (A59228)
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
