PVC pipe
/ PVC pipe #1
GlennT
Fredericksburg, TX
John Deere Model 670
I'm chugging along slowly on my rainwater collection system. At a seminar I attended recently, the speaker mentioned that Schedule 40 PVC pipe needs to be painted as the ultraviolet rays from the sun will cause it to deteriorate. That's the first time I've heard or read that. Is this true?
/ PVC pipe #2
GlennT
Hope not. My well appears to be made of the stuff and the top of it sticks up about a foot. I would suspect that it is both true and not true and probably depends on both the location and intended use. Our local hardware stores it's PVC outside and so does the plumbing shop.
On the other hand, plastic does degrade in the sun. Think about a milk jug that's been left out for a few years. They just start coming apart in pieces.
SHF
/ PVC pipe #3
Yes, GlennT, it's true to some extent at least. It may last a long time in the sun if it's not disturbed, but I've had just a little experience with working with Schedule 40 that had been out in the sun a couple of years and it just seemed excessively dry and brittle and easy to crack or shatter.
Bird
/ PVC pipe #4
White latex house paint is frequently used for this.
<font color=green>stan</font color=green>
/ PVC pipe
As usual, I had a problem, asked a question, and got my answer. Thank you for the information. I'll lightly sand my PVC pipe to take some of the gloss off and then paint it. A preliminary coat of KILZ and then a final coat of latex to match the trim on the house should do the job. Thanks again for the help.
/ PVC pipe #6
You might try PVC conduit. It's UV stabilized.
/ PVC pipe #7
Yes, it's true. It might be fine in low-pressure situations for quite a while, but UV does deteriorate it. Schedule 80 PVC has a little more resistance, but the best option is to bury it, or keep it inside out of the sun. Exposed pipe should be metal, or UV-stabilized PVC, or protected from UV.
Electrical conduit is IV-stabilized, but it won't handle the pressure that schedule 40 or 80 will handle.
The GlueGuy
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
ROOM WITH MISC ITEMS (A67714)
ROOM WITH MISC...
Vibratory Plate Compactor (A64553)
Vibratory Plate...
2026 SG45 Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2026 SG45...
CATERPILLAR 249D3 SKID STEER (A65054)
CATERPILLAR 249D3...
2018 CASE 750M WT CRAWLER DOZER (A65056)
2018 CASE 750M WT...
