Putting wood over steel deck trailer
   / Putting wood over steel deck trailer #1
FreeWulf
Between Portland and Seattle
None now
I'm looking at a potential trailer. It's heavy enough, but it has a steel deck and I'm NOT a fan of steel. Too slippery, loud, etc.
I'm wondering why I couldn't just drill some holes and bolt wood over the top of the steel, at least on the tire track sides.
Would this cause the wood to rot too fast though? I'm in the PNW, so it rains a lot. I can picture the steel trapping water on the underside of the wood and not draining.
   / Putting wood over steel deck trailer #2
Paint the floor & while it is wet sprinkle some blast sand over it. When it drys you have a non-slip steel floor that will last forever.
   / Putting wood over steel deck trailer #3
Yea, if you screw wood to that metal floor the wood will rot and the floor will rust. It'll last for probably several years before it does. I'm with cw, sand it and use it. I had a metal floor trailer for years with no issues. If it's built right it won't be noisy.
   / Putting wood over steel deck trailer #4
Bedliner
That's not a bad idea at all. I've done something like that in the past with Fiberglass.
That was my first thought other than wood actually. I'm wondering about in a light color so it doesn't get as hot too. Although white would start to look terrible with dirt getting ground into it.
   / Putting wood over steel deck trailer #6
Khaki/beige/tan color cars look the same when dirty or clean.
   / Putting wood over steel deck trailer #7
+1. Your plan will cause the steel deck to rust out quite quickly. ...And probably rot the wood too as the other poster noted.
   / Putting wood over steel deck trailer #8
From experience, I'd call sprinkling sand on wet paint worthless since it comes off to easily. They do make a paint that's for making a floor tacky but I've not used it.
   / Putting wood over steel deck trailer #9
There are also strips of non-skid stick on material available.
   / Putting wood over steel deck trailer #10
When I had a new milking parlour put in 50 years ago, the concrete where the cows stood to be milked was floated up to a smooth surface, carborundum dust was sprinkled on and the surface was floated again. It always looked very smooth but it had tremendous grip.
JOHN DEERE 7210R LOT NUMBER 270 (A53084)
JOHN DEERE 7210R...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
2022 John Deere Z950M Zero Turn Mower (A51573)
2022 John Deere...
WESSEX CRX 240 LOT NUMBER 169 (A53084)
WESSEX CRX 240 LOT...
John Deere Z915E Zero Turn Mower (A51573)
John Deere Z915E...
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
