Putting up a metal garage ceiling with my tractor
   / Putting up a metal garage ceiling with my tractor #1
carpenter383
Platinum Member
Indiana
Kioti DK40SE
Here are some pics of my weekend project:
I bolted a 10ft wide frame built out of lumber to my tractor bucket (the holes were in the bucket from the factory) and used it as a platform to lift 20ft and 16ft sheets of metal to the trusses which are 12ft high. and 4ft O/C.
It worked out great and I was able to get it all done in most of last weekend by myself.
I'm gonna blow about a foot or so of insulation on top of the metal. I framed the walls with 2x6's and used r19 in them and I think it should heat pretty easy this winter. I'm gonna heat it with a wood boiler:D
   / Putting up a metal garage ceiling with my tractor #2
thats ingenious. Could hang drywall with ti too if needed.
   / Putting up a metal garage ceiling with my tractor #3
Great job. I plan on using the white metal siding for the ceiling when I get around to having our pole barn built. Thanks for posting the pics, great idea and set up with the FEL.
   / Putting up a metal garage ceiling with my tractor #4
Great idea! Good photos, too. It looks like it came out very well - thanks for sharing with the photos.
   / Putting up a metal garage ceiling with my tractor #5
Impressive!
   / Putting up a metal garage ceiling with my tractor #6
Looks good. I need to do that as well. Too bad my ceiling is 14' high. :(
   / Putting up a metal garage ceiling with my tractor #7
Looks Great ! ! ! Like the frame for installing the panels Great idea
   / Putting up a metal garage ceiling with my tractor #8
That's really slick. I am also very glad none on the pieces slid off and made two parts outta you! You got a huge amount of work done...really impressive.
Peter
   / Putting up a metal garage ceiling with my tractor #10
Carpenter,
Excellent example of what can be accomplished in a weekend by a clever man and a versatile tool.
With 4' O/C truss spacing, do you have any concerns about undesirable deflections of the ceiling under the load of 12" of blown insulation?
- LogChain
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2011 Doonan 482FBCHTTDBZ 53ft 40 Ton T/A Flatbed Equipment Trailer (A52377)
2011 Doonan...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
205028 (A52706)
205028 (A52706)
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
