Putting two cylinders into the same remote
   / Putting two cylinders into the same remote
My JD does NOT have a loader on it, and is two wheel drive, which is why the Kubota is, in most cases, better suited to pull the batwing. I don't have any current pictures of the remote valve, either the one on the JD or the one he gave me. (They are different in appearance, but similar)
I am thinking to try the JD on the banks, I will just "Y" one of the remotes, since that is the cheapest route. If that works, and I can get to a significant amount of the pond bank with 2wd, then I will just use the JD. If I have issues with keeping the JD from sliding down the bank, or failing to be able to climb up hill when needed, then I will look into using the Kubota.
David from jax
   / Putting two cylinders into the same remote #12
Your Kubota has an open center hydraulic system. What tractor did the green valve come off of? Many valves can be converted in one way or another, just have to know what you're dealing with.
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2012 International Prostar (A56435)
2012 International...
2016 Ford Edge SUV (A56859)
2016 Ford Edge SUV...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2020 DRAGON ESP...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
