sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 5,930
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
I have two tractors, one with a single remote but it has hydraulic's on the FEL(Kubota M7040), the other has two remotes (JD2555). I want to pull a batwing mower that has 3 hoses, one from each wing and another for the rear lift cylinder. I would prefer to run the batwing off of the Kubota because it is 4wd and that is what the owner said he pulled it with. If I run it off the JD, I will have traction issues on the side of the pond. The batwing was purchased to get closer to the pond without having to drive on the ponds edge. The rear lift is required pretty much, and wing cylinders are also needed, although I could use one line for both lifts which would allow me to make up a "Y" configuration. There are also one to two adapter blocks (at the tune of about $299). I also could bite the bullet and have Kubota dealer install another pair of remotes, to the tune of about $1800.
I was wondering what grade of steel pipe I should use in case I want to build my own "Y" fitting. The actual fittings are available at Tractor Supply with pipe threads but for some reason I remember standard pipe is not rated for hydraulic pressure. Any suggestions on what type pipe will work or another way to do this?
David from jax
David from jax
