Putting in new hydrolic piston seal 1700
   / Putting in new hydrolic piston seal 1700 #1
rayikeo2
Platinum Member
I found a cracked seal on my 3 pt lift piston and am ready to install a new one, I have it ready to go on the piston. Is there a trick to installing the seal or do I just stretch it over the piston? I am thinking some of you that have done this before might have some pointers for me. Ray
   / Putting in new hydrolic piston seal 1700 #2
Without seeing a picture...I can only guess what it looks like, BUT I use the trick of boiling the seal in water for a few minutes to soften it before stretching them on.
It is about 3" diameter made of a vinal? or plastic has a cream color to it. Sorry no pictures, I thought warming it up might help as long as it returns to original strength and size, Ray
   / Putting in new hydrolic piston seal 1700 #4
please refer to the other post you made about the same subject with explanation on how to.
bad seal, look at the seal orientation.
New seal install, don't have a macro shot to show you the orientation, it is same as old, use no tools, lube and slide it in, tight fit.
   / Putting in new hydrolic piston seal 1700 #5
Just like JC-Jetro says. Heating it won't do much good unless you heat the piston too. Don't use boiling water, most of these seals are only rated for 210 degrees. The cool metal will suck the heat right out of the polyurethane anyway. Just lube it and push it on with your palms.
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
1993 Trail Boss Lowboy Trailer (A52384)
1993 Trail Boss...
1986 Wisconsin 24' Tilt Deck Trailer (A52384)
1986 Wisconsin 24'...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
