putting green
   / putting green #1
newtractorowner
does anyone know how to construct a putting green? I have an area about 35' in diameter scraped down to the hard pan clay. I wonder if I can just put top soil over the top of the clay. How much slope to the hole? Any help would be great.
   / putting green #2
A friend of mine worked on a grounds crew, and we discussed this topic a few years ago.
Once you have a compact, graded surface (your clay), dump approximately 6-8 inches of #2 stone, which is then topped with quarry dust and packed down firm. This apparently provides a stable, yet porous base, allowing your topsoil to drain.
According to my buddy, this is where you will shape the surface of your green, by providing the undulations/breaks, etc.
You will then top your green with 10 inches of the finest topsoil that you can afford. There are a number of varieties of grass that work well in different areas of the country.
For drainage, remember: the slope of the clay should reflect where you want the water to drain. Good luck.
   / putting green #3
   / putting green #4
newtractorowner,
Check with Murf over on the Compact Tractor Board. His company builds golf courses in Canada and the northern U.S. http://www.jplan.com
2012 Ford F-450 (A50120)
2012 Ford F-450...
2013 Ford F-550 4x4 Altec AT40M 40ft Bucket Truck (A50323)
2013 Ford F-550...
Raven BSR (A47384)
Raven BSR (A47384)
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2012 Hino 262 Rollback Tow Truck (A50323)
2012 Hino 262...
