Putting eyes in cable...
   / Putting eyes in cable... #1
JimS
Bronze Member
I have several sections of 1/2" cable I use to pull down trees, etc. I do a Molly Hogan (aka Flemish Eye) and put one cable clamp on the tail. Works great and if the clamp is checked for tightness from time to time they are almost as strong as the cable itself. My question is what to do about the cut end. Over time they fray and make a mess of sharp wires. I wrapped them with tape but that didn't last long. I suppose I could bind the end (think there is actually a term for this) with cord. Looking for ideas. Have even thought of using some heavy plastic heat shrinkable tubing.
   / Putting eyes in cable... #2
Maybe copper tubing crimped or soldered on the end.
I've always wanted to try the "spelter socket" ends but never ran across the materials.
Bruce
   / Putting eyes in cable... #3
What about ox/ace torch with welding tip, and melting the ends into a ball? would that work?
James K0UA
   / Putting eyes in cable... #4
Cut ends I usually burn them in a ball with the oxy/acet torch, then grind the rough spots smooth
   / Putting eyes in cable... #5
James K0UA
Ya beat me to it...:thumbsup:
   / Putting eyes in cable... #7
yep a minute late...:) I have never done it. but seemed like a good idea to me..
James K0UA
   / Putting eyes in cable... #9
You could learn to do real splicing.
In this way the ropes don't come apart and over time the sprags end up inside the rope.
http://www.worksafebc.com/publications/health_and_safety/by_topic/assets/pdf/splicing.pdf
there are other manuals on splicing on line
Manual on splicing - Google Search
Put a big enough eye splice (or Flemish Eye) on the cut end to pass your Molly Hogan through.
Then you can snare your tree with the business end and have a quick hitch to a ball, hook or D-ring on the pulling end.
I might try the copper crimp. The torch seems like the best idea but don't have a torch. Might get a friend to do it.
The real splicing links are very interesting. I remember my dad who was a logger in his early years talking about the old timers splicing line that would go through pulleys. Might try it sometime when I have some time.
The big eye to loop around has a good chance to kink the cable and weaken it, IMHO. I prefer to wrap the cable a couple times around the tree and secure the end with a clevis. With the friction of the wraps the end has very little tension and the larger clevis pin has less chance of kinking the line.
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2018 Freightliner M2 106 Altec LR756 Forestry Bucket Truck (A52377)
2018 Freightliner...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
