Backhoe putting backhoe att.back on 07,ck30
   / putting backhoe att.back on 07,ck30 #1
blkdaze
comstock,new york
2007 kioti ck30
every time i put the backhoe back on my 07 ck30,i can never get the bottom hyd.hose back on.am i doing something wrong.i have only had the bh on and off 3x,and that bottom hose wont go on.any advice.thanks
   / putting backhoe att.back on 07,ck30 #2
You could have pressure in the hose or fitting that keeps it from snapping on. You could try to bleed the fitting of pressure to see if that helps. Machine may have to be on when connection is made. I have same problem attaching snowplows on trucks. plowking
   / putting backhoe att.back on 07,ck30 #3
If the pressure is built up from expansion or settling it won't connect in the QC. I have put a rag over the stuck coupler and tap with a hammer to relieve the pressure. Once some fluid is released (why the rag is used) it couples up easy. My FEL will do the same thing no matter how much I relieve the pressure when removing.
Easy to remedy by just releasing some fluid
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2019 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2019 CATERPILLAR...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2004 FORD F-350 (A50323)
2004 FORD F-350...
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
