Backhoe putting backhoe att.back on 07,ck30
   / putting backhoe att.back on 07,ck30 #1
blkdaze
comstock,new york
2007 kioti ck30
every time i put the backhoe back on my 07 ck30,i can never get the bottom hyd.hose back on.am i doing something wrong.i have only had the bh on and off 3x,and that bottom hose wont go on.any advice.thanks
   / putting backhoe att.back on 07,ck30 #2
You could have pressure in the hose or fitting that keeps it from snapping on. You could try to bleed the fitting of pressure to see if that helps. Machine may have to be on when connection is made. I have same problem attaching snowplows on trucks. plowking
   / putting backhoe att.back on 07,ck30 #3
If the pressure is built up from expansion or settling it won't connect in the QC. I have put a rag over the stuck coupler and tap with a hammer to relieve the pressure. Once some fluid is released (why the rag is used) it couples up easy. My FEL will do the same thing no matter how much I relieve the pressure when removing.
Easy to remedy by just releasing some fluid
John Deere 603 3 pt Mower (A50514)
John Deere 603 3...
TRAILER AXLE (A51244)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2014 Caterpillar 257D Compact Track Loader Skid Steer (A50322)
2014 Caterpillar...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
