Puter Guys Help Me
   / Puter Guys Help Me #1
MarkV
Super Member
Cedartown, Ga and N. Ga mountains
1998 Kubota B21, 2005 Kubota L39
Puter Guys Help Me
My darn cursor acts like it is having a seizure the way it is jumping around. Wants to keep going to the scroll bar on the right. If it wasn’t so hard to use it would almost be funny. You have to time your hit on the mouse button as it flies past the subject line you want to highlight. /forums/images/graemlins/crazy.gif
Any of you that know computers have any ideas for me to try?
MarkV
   / Puter Guys Help Me #2
Mark,
I think you need a new mouse. If you're hesitant to spend all that money, just borrow a mouse from another computer and see if it performs the same way. I'm betting it won't. /forums/images/graemlins/grin.gif
   / Puter Guys Help Me #3
MarkV, I'm sorry to tell you this but your mouse may have a dirty ball /forums/images/graemlins/grin.gif Try this, If you have an older mouse with a ball in it
remove the ball by twisting or popping off the plastic disk that holds the ball in place. When the ball is out take a Qtip dipped in alcohol and clean the contacts inside the mouse. This may help.
   / Puter Guys Help Me #4
I had problems with the ball in my mouse getting dirty also. I'd clean it and everything would be fine, but it was just a matter of time untile I needed to clean it again.
One day I was buying something and noticed a mouse that didn't have a ball. It workes off the same priciple, but uses infa red or something like that. No moving parts to roll around. No need for a pad, and best of all, no more problems.
Of couse, I was using my computer in a barn I was converting to a place to live in, so you probably don't have the dust issues I was dealing with.
Eddie
   / Puter Guys Help Me #5
I use a track ball and it's normally been a dirty ball when it behaves this way. I pop the ball out and clean the contacts, too. I also have a slow, on its way out pc set up, I don't know why, I bought another to replace it that is up and running, but anyway, the cursor behaves this way when it is hung up doing something else, like checking for email.
Use your finger to see if the cursor moves easily without jumping around. If it does then it's probably a dirty ball/contacts and it's just skidding along the mouse pad when used normally.
   / Puter Guys Help Me #6
Is this on a laptop? Kinda sounds like it. button mouse?
Does it happen after reboot? If so seams like device needs to be calibrated...in settings/control panel/mouse... /forums/images/graemlins/smile.gif
If it a desktop clean axis wheels if its a ball mouse, or get an optical mouse
   / Puter Guys Help Me #7
MarkV,
If you are already using an optical mouse, I've noticed this kind of behavior if I use one on a wood surface, or even wood grain Formica. Put a piece of cardboard or a mouse pad under it and it should be fine. Otherwise, see the other comments.
Mike
   / Puter Guys Help Me #8
If it's a ball mouse, remove the ball and take an exact-o knife and clean all the gunk and fuzz off the black and white rollers inside by using the knife to scrape it away.
   / Puter Guys Help Me #9
I just used to use my fingernail to clean the rollers, but a lightmouse is the right answer - end of problems. I think you can buy them now for less than $10, worth every penny IMHO!
   / Puter Guys Help Me #10
I clean mine occasionally, but I didn't even know they made a mouse without the ball. /forums/images/graemlins/laugh.gif
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2014 TOYOTA 8FGCU25 FORKLIFT (A51222)
2014 TOYOTA...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
2012 Infiniti G25 (A50324)
2012 Infiniti G25...
