Put a Turbo on a B2630 good or bad
   / Put a Turbo on a B2630 good or bad #11
I have a B2630, 2010 model. Would it be feasible to put a turbo on it for a little extra power. Some times I find the need for more power. I only own 15 acres so a bigger tractor is not really necessary.
I would confirm that the pistons have steel inserts to hold the upper ring set. Much boost on non steel insert pistons can pound the ring lands out of shape leading to a major loss of compression.
   / Put a Turbo on a B2630 good or bad #12
I have a Kubota B2630. Sometimes I find the need for more power. Would it be feasible to put a turbo on it for a little extra power?
I own 15 acres so a bigger tractor is not really necessary.
Have you considered that you may need more tractor WEIGHT rather than more horsepower?
Weight establishes tractor capability.
Horsepower largely determines what width PTO-POWERED-IMPLEMENTS can be powered.
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower.
  • Kubota B2630 = 1,766 pounds bare tractor
  • Kubota L2501 = 2,600 pounds bare tractor
Small tractor wheels drop into holes, disrupting traction. Larger wheels and tires supplied on heavier tractors bridge holes and ruts, increasing traction. Larger wheels and tires permit higher operating speed over uneven ground by reducing implement bounce and operator perturbation.
When considering a tractor upgrade bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
GERMANE VIDEO:
Very germane and I'm not a fan of Messicks anyway. I will say that owning pre 4 equipment is a big plus for me at least. My tractors are actually appreciating in value. When a dealer offers me 30 grand for a 6000 hour machine that is a 2002, I know I'm on the right track. Especially when the machine was only 45 new in 2002.
   / Put a Turbo on a B2630 good or bad #13
Jeff9366 always shares wise advice! I haven’t found one post I disagree with. And, he is correct here too. For work, tractor weight is king!
However, a smaller tractor can benefit from a turbo by increasing the PTO HP allowing the tractor owner to use larger attachments/Implements like, for example a larger wood chipper or flail mower (assuming the tractor can lift and carry them reliably).
Mike
Wheels are loaded. I definitely need chains. My property go up on the rear third. If we get some significant snow I cannot get up the hill. Or pull logs for firewood.
   / Put a Turbo on a B2630 good or bad #15
Now, this is a post that will make you think.... moving from naturally asperated to turbo.
   / Put a Turbo on a B2630 good or bad #16
Adding a turbo seems like a lot of mods. Modifying the intake, exhaust, brackets, oil lines.
Why not turn up the pump or play with timing? .....if possible.
...but you know, eliminating engine power as the “weak link”, just makes something else the weak link.
   / Put a Turbo on a B2630 good or bad #17
GERMANE VIDEO:
Ag tires will make a big difference. I have a little 3130 that does a lot of work, albeit more slowly than a higher horsepower rig. A heavy implement on the rear helps, as does a good hand on the front loader. Nothing like a bucket of dirt for a little extra traction. I have to admit that 45 hp would let me power through where 31 hp makes me slow down, but it's a utility tractor, not a field tractor.
   / Put a Turbo on a B2630 good or bad #18
It would take some fabrication skills to do but then you have to add fuel. Do you have the skills to get the injection system to add more fuel and at the right time.
   / Put a Turbo on a B2630 good or bad #19
Know what happens to an engine that doesn't get the right amount of fuel?
Not only that, but how do you ****** the fuel timing when boost goes up? A 'chip' that can only guess at the boost?? I strongly suspect that the injection event is different on a TurboCharged engine than it is on a N/A engine; especially at boost
An Internal Combustion Engine is nothing more than an air pump. High pressure from the compression stroke of the piston coupled with fuel combustion/ignition makes the pistons move and gives you power.
The OP wants to change from Standard Atmospheric Pressure to Boosted pressure. By how much? 6 Pounds?? 15 Pounds???? Putting twice as much air into the combustion chamber.
Anybody have any idea what happens to an engine when it has too much compression??
Then there's powering the turbine. How, exactly do you intend to do that? Can you run water AND oil to the bearings in the turbine?? Are the bearings going to be ceramic or steel?
I don't mean to be a Neg but just do what I told you earlier.... If you don't think you've got enough power, or if you want more power (you don't need a reason, you just do) then trade or sell your tractor and get what you want.
Because I'm gonna tell you something straight up..... If you have to ask this crew what they think about doing it, you're already in deep doo-doo.
No offense :)
ETA:
If you are serious about thinking about it, go to a Turbo Diesel Forum. See what they think. Some of them have some very knowledgeable people.
   / Put a Turbo on a B2630 good or bad #20
Here is a guy that added a turbo on his Kubota ZD326 with a 26 hp engine as well. Although it's a D1005 versus the D1105 on the B2630.
I've thought about doing it on my homemade backhoe with the D640 engine as well, just haven't got around to do it yet.
John Deere 5075E (A53317)
John Deere 5075E...
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
2016 KENWORTH T680 SLEEPER (A57880)
2016 KENWORTH T680...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
