Pushing over cedars
   / Pushing over cedars #1
txloops
Is there a "right way" to push over small trees with a tractor/FEL? The dealer said you can do it....but didn't explain HOW. I'd appreciate any tips...want to be productive but safe.
   / Pushing over cedars #2
With my small Kubota, I bring the loader bucket up about 4 ft off the ground, put the tractor in low, roll up and stop with the bucket just touching the tree, hit the differential lock, and press the hydro pedal all the way down. Usually it will push over a tree about six inch diameter at the base, but not a six inch Florida Pine. Once the roots have pulled up a little on the side where the tractor is, I dig down a few inches with the bucket, used the same procedure to push forward, but curl the bucket up after it goes under the roots. Repeat these two steps a few times and most small trees come right out. With a tree that has a real deep root ball, I've been digging around with the backhoe a little before I push it over.
I don't know if there's a right way or not. Just go with trial and error, without beating up the tractor. In other words, no full speed ramming action and you should be OK.
   / Pushing over cedars #3
txloops,
Welcome to TBN.
I do pretty much what aardvark is recommending (although I don't have cedar).
Please fill out your profile when you get a minute so we know what type of tractor and "stuff".
To elaborate on a couple things:
I don't have hydro. If you have a gear driven tractor, put it in it's lowest gear and have the RPM's up a little when you go to push.
Be careful if the tree is dead. If/when it comes back, the top can snap off from the rocking and come down on you and/or your tractor.
When using the bucket to push on the tree, try to keep the bottom of the bucket perpendicular to what you're pushing on. If you put the bottom (flat side) of the bucket flat against the tree, it may bend your bucket.
When the tree goes over, watch the root ball on the near side. Depending on the diameter of the root ball, it'll sneak up under your tractor. You don't want to get hung-up nor have the roots damage something in the front or undercarriage of the tractor.
Brian
   / Pushing over cedars #4
Be careful not to back up with the cedar or any tree under the tractor where the limbs may catch your hoses or get under your tractor hood and break it. Tree limbs under the tractor can do damage if they get lodged while backing up.
   / Pushing over cedars #5
<font color="blue"> "... and press the hydro pedal all the way down. Usually it will push over a tree about six inch diameter..."
<font color="black"> Gear guy myself but doesn't pushing the hydro pedal increase the gear ratio which would reduce the pushing force?
John
   / Pushing over cedars #6
</font><font color="blue" class="small">( doesn't pushing the hydro pedal increase the gear ratio which would reduce the pushing force? )</font>
Yes, and if you do it quickly you can stall the engine. If you do it slowly, you'll either go, or spin the wheels, or hear the engine bog down a bit and a relief valve will open without killing the engine. At least that's the way it worked on both my Kubotas.
   / Pushing over cedars #7
Thanks. Sounds like Jared has power to spare.
   / Pushing over cedars #8
Not too much power to spare, I just live in a sand pit, also known as south Florida. /forums/images/graemlins/smile.gif The soil is so sandy down here, most stuff comes out really easy.
Also normally I press the pedal down pretty slowly, it's not a "stomp on the pedal" procedure. If the pedal is all the way down, the root ball is on it's way out and I'm keeping the tree moving the direction I want it to go. That, and the BX23 low speed selection seems really low, but I haven't really used many other tractors to compare it to. I guess I wasn't clear in my first post, should have thought it through a little more.
Thanks to all for the replies and advice. This site is proving to be invaluable to a "newbie" tractor owner. I don't have Hydro on my tractor...but I understand the differential lock and slow approach.....sounds like a plan!
   / Pushing over cedars #10
We live in a hilly area of rock, swamp and hardwoods and seem to be forever building trails for skidoos or 4wheelers. It is a lot easier to push atree out, roots and all than cut it off and then dispose of the stump. I have found that if you can get a tree to rock and move a bit at the roots, you can normally push it over. The secret is to remember that the higher on the tree you can push, the more leverage you have. Each time you rock it, a few more roots break. Sometimes you have to remove a bit of dirt with the FEL and sometimes you have to turn around and pull with a LONG strong rope, tied as high as you can reach. It also makes a difference if the soil is dry or wet and what kind of tree it is. Poplar and cedar tend to break off if pushed too hard, birch tend to drop branches on you and oak is a real challenge. Most maples in our area (less than 12" dia) come out fine. Pat
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2017 KOMATSU  D61 PXI-24 (A52472)
2017 KOMATSU D61...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
