Pushing back the edges of the fields
   / Pushing back the edges of the fields #1
pennwalk
Veteran Member
Lancaster PA
Yanmar 186D
Now that the corn is down and the weeds have died back I have been bush hogging the edges of the fields. I love my kk bush hog. :D I got to wondering if it would be better to wait until early spring? What do you guys think?
Chris
   / Pushing back the edges of the fields #2
If it is dry enough now AND you have the time , i would do it now, and then if the spring weather is decent won't hurt to do it again.
   / Pushing back the edges of the fields #3
Fewer bugs generally now, especially if you live in a Lyme Disease area as the tick nymphs are active in the Spring.
   / Pushing back the edges of the fields #4
pennwalk:
I would do it when the ground is dry. I do not know about PA, but it has been pretty "wet" in MA this year. I have ruts everywhere. I have had ~40" of rain and melted snow so far this year, and it seems to rain whenever I have time off :(. Jay
   / Pushing back the edges of the fields #5
I like to beat the edges back now. Once the weather gets colder, as it is now the stinging varmints are much less likely to give you a hard time.
The conditions were pretty good last week but the Water Authority was draining the water tank so we had a river running down the middle of the property. I had to call the cops to find out what was going on. I was a little worried because the water was bubbling up from the field. I could just see the Water Authority claming that I hit the pipe with the plow and that will be 1.6 million to fix it.:eek: I hope the weather is nice this week and I will be able to do some more hoggin.:D It can get muddy in the spring in fact there is a spot in the back that almost ate my little yanmar last spring. I was very suprised cause that little guy can almost swim. If I can get the weeds knocked back I may try to get hold of a pole saw and prune the trees back a little.
Chris
   / Pushing back the edges of the fields #7
Chris, you might be a prospect for some rice tires if that continues.
   / Pushing back the edges of the fields #8
Chris
Any time is a good time to bush hog. I did some on my property just to make things wider. I am moving on to some land adjacent to mine that will never be built on. Added an extra 50 feet to my land in some areas. More land for the farmer who leases my property. And fewer weeds.
Bob
   / Pushing back the edges of the fields #9
Chris
You just answered your own question :p
   / Pushing back the edges of the fields #10
Do as much as you can now and all winter long, then in the spring time, it will be an easy job to clean up the new growth and do a little more.
Eddie
(1) 24' CORRAL PANELS W/ (1) 12' GATE (A51243)
(1) 24' CORRAL...
2012 JOHN DEERE 850K WT CRAWLER DOZER (A51242)
2012 JOHN DEERE...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
Stump Bucket (A50322)
UNUSED CFG INDUATRIAL SSECAG-Y AUGER BITS (A51244)
UNUSED CFG...
