Pushing A Tractor To It's Limits
/ Pushing A Tractor To It's Limits #21
Not even sure what he was trying to accomplish.
He was doing more damage to that slope/dam by spinning the tires than he was repairing.
Tractor was using 99% of its ability to stay on the slope....and 1% of its ability to move half a wheelbarrow load of dirt.
Exactly my thought as well. Clearly that tractor didn't make the dam/slope. Why even drive across it like that?
I guess there was a small ridge of spoils left behind by the bulldozer or something... that he wanted to flatten out? Sheesh.
/ Pushing A Tractor To It's Limits #22
I don't know about the limits of that tractor. Certainly pushing his intelligence beyond all limits.
/ Pushing A Tractor To It's Limits #24
Looks like he's practicing to be a sprint car driver... glad he didn't have a mishap.
/ Pushing A Tractor To It's Limits #25
/ Pushing A Tractor To It's Limits #26
I don't think he was even close to rolling...I didn't see any of the tires off the ground
My guess, for better or worse, the guy has been doing his for years...
I agree Roy. The slope was solid with plenty of "marbles" under the rear tires for them to scoot on. As long as he kept the left rear tire below himself he couldn't roll. Would slide down the bank first.
I wish we had the operator in this discussion. He would get a kick out of the responses. :)
/ Pushing A Tractor To It's Limits #27
Exactly the problem. If you do something wrong for years and survive you ignorantly start to think you are invincible or what you are doing is fine. It only takes once for it to turn tragic.
As is the case when you mount/dismount your tractor. Climb or descend a ladder. Clean the gutters on your house. Go ice fishing. Drive your ATV/UTV down the road. Jump out of the back of your pickup. Etc., etc. :giggle:
/ Pushing A Tractor To It's Limits #28
Looks to me like a guy who knows exactly what his equipment is capable of and is doing the best he can with what he has. I've got 5000 hours on tractors and 6000 on other heavy equipment as a landscaper, and I get put in this type of situation all the time. I have never flipped. Ditches, berms and grades still need to be finish graded and mowed. Is what he's doing optimal? no, but not everyone can afford the perfect equipment for the job. I think the problem is people assuming the operator is as inexperienced as they are.
/ Pushing A Tractor To It's Limits #29
I don't think anyone is going to argue with what you're saying. This is one of those examples where there are other tools more suitable for the job.
Of course, but it's going to cost money.
/ Pushing A Tractor To It's Limits #30
You can say the same thing about race car drivers.
/ Pushing A Tractor To It's Limits #31
There may be tools more suited for the job, I expect that if they had them or reasonable access to them they would have been in use.
They used what was available to accomplish what they wanted to.
Also it was quite possible that those two tractors with blades and offset disks did do all the work that was visible. Other larger heavier equipment would be faster but if you don't have it, you do the job with what you have.
It wasn't too many years ago that many major feats of building were done in this county without nice cushy modern equipment,
think the canal systems, the railroads, bridges. Even the first graveled roads.
Think what that Irishman digging a ditch with a pick and shovel for 35 cents a day would have though seeing equipment like that.
/ Pushing A Tractor To It's Limits #32
Quite right. They don't work like that for thrills.They have to do it to put food on the table.
/ Pushing A Tractor To It's Limits #34
Finally after 27 posts, we get a good one!!!! You are absolutely correct. (y)
/ Pushing A Tractor To It's Limits #35
Another excellent post.
/ Pushing A Tractor To It's Limits #36
With barely no weight on the front, with a little right brake he can get that tractor to turn uphill in a second if slope gets “really” sideways tippy.
Plus a tire that is spinning will crab-walk slide versus one that isn’t and plants itself as an anchor to flip.
/ Pushing A Tractor To It's Limits #37
Yep. I've had the Road Grader on slopes so steep if I try to pick up the moldboard the high side tires come off the ground. As long as you keep the nose uphill and let the rears "drift" life is good.
/ Pushing A Tractor To It's Limits #38
/ Pushing A Tractor To It's Limits #39
To me, if i could see what the benefit was i might would agree with those that thought he was okay, but i couldnt see anything that justified the risk…
Of course, you couldn't. You have never been in a position where there are a hundred guys who would take your job that go with the risk. We Americans have no idea what the deal is overseas.
/ Pushing A Tractor To It's Limits #40
That is an operator that know the limits of his equipment and works right up to them. Lots of discussions about tipping and may reasons he didn't, but i'll add that the disc harrow hanging out to the side is like a kickstand, if he he gets a few degrees farther over, it will ground out and stop a roll before the CG gets too high.
Towable Road Crossing / Pipe Bridge Trailer (A63689)
Towable Road...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2024 MACK DUMP TRUCK (A63276)
2024 MACK DUMP...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
