Purple Ice
   / Purple Ice #1
sirgknight
South Georgia
Early model YM1700
I was watching an automotive show on tv and saw this advertisement for purple ice. It's a product designed to add to the radiator coolant to further reduce the operating temperature of the coolant as it circulates. Just wondering if this product would be suitable for our Yanmars without water pumps. Does anyone have any input or data on this product and how it would work for us?
   / Purple Ice #2
I would be leary of any product in the thermosyphon system.. The improper coolant mixture allows one to overheat, so it makes sense that any additive that cools the system in a "special" way would definitly cause problems(in my mind).... I wouldnt waste my money...
   / Purple Ice #3
It's much better to fix the problem than to try to mask it with additives.
   / Purple Ice #4
It sounds to me to be similar to "water wetter," which some on this board have recommended for thermosiphon systems.
   / Purple Ice #5
There are several products on the market which improve the thermal conductivity of water. I believe the purple ice is made by Royal Purple which is a reputable company with a strong background in racing. If you have a marginal overheating problem or just want to be more confident in your machine, then it can't hurt.
   / Purple Ice
Ever since adding gauges to my 1700 the temp gauge has constantly read between 210 and 230 degrees. In addition to using the gauge I also kept the original idiot light attached for extra precaution. The light has never come on, the radiator coolant has never overflowed, the tractor has never acted sluggish and in the two years that I have owned her I have only had to add about 1/2 quart of coolant mixture (60% distilled water and 40% coolant). The temp reading has me constantly concerned and I watch it like a hawk. Cord is correct about the purple ice being used in racing situations. It's not designed to cover up a problem that needs fixed but is actually added to completely rebuilt and new engine applications for extra protection. Do my operating temps indicate an underlying problem with the radiator system?
   / Purple Ice #7
The right mix for the 1700 would be 70% and 30%, it will run cooler with it mixed right. You are having too much antifreeze in it, which will make it run hotter. And from where you are you shouldn't have to worry about it freezing.
   / Purple Ice #8
""Do my operating temps indicate an underlying problem with the radiator system?'
Yep, I'm betting you have a plugged radiator or block.
   / Purple Ice
Norm, what steps do you recommend I take to check out your theory? How would I check the block?
   / Purple Ice #10
First, make sure the outside of your radiator is not plugged with mowing chaff, (blow through it from the engine side with water or air). then back-flush the system by disconnecting the upper rad hose at the rad, run a garden hose into the upper hose and seal with rags. Turn on the water and see what comes out the upper connector, flush til clean. (You might want to unhook the battery and cover electricals with plastic). If still running hot, time for rad shop test and rod job.
Ih 490 Disk (A50514)
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2018 FORD F-150 (A50854)
2018 FORD F-150...
2016 LINK-BELT 235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
