electrycmonk
- Joined
- Nov 6, 2018
- Messages
- 212
- Location
- Near Denton, TX
- Tractor
- Satoh 370 diesel & Cub Cadet 7260 Diesel 4WD standard
(newbie wave) I've spent the last 90-odd minutes with the search functions and tried what *I thought* would be wise words.... struck out across the board.
Problem: hydraulic system is water contaminated.... by me, accidentally- it seems. I went to pour some sealed 5gal. jug of TSC 303 that i'd had in the garage for a while(2-3 years but still factory sealed bucket).... well that was a big mistake.... about the time i realized what i saw in the stream of liquid - it was too late to stop.
I had to do some moving of stuff so I did use the Cub for a bit that day and while using it the FEL lifting cylinder (clutch pedal side) gaveout and started leaking at rest and faster in use.....
got stuff moved. PArked it.Removed the cylinder and took it to the local rebuilder shop as I didn't have the time or space to do it myself this time. so Now its cleaned and rebuilt.
I poured in some of the 1st bucket and started the tractor for a few seconds and pulled on the joystick to purge a bunch of the milk out the FEL pipes from that cyliner location.... stopped and called it a night.... came inside and started searching.....
So now I want to purge OR just clean the system as quickly as possible.
Here is the tractor specs in question:
cub cadet 7260 with FEL 417
i found the manual in pdf (some 300 pages) downloaded it.... will look at it in the AM to find the exact(suggestions) for drain plug location(s). I shall drain it tomorrow AM.
I did stop by a local tractor repair shop and was told to get a couple buckets of TSC 303 and just drain, and run. Then drain and run. and he said to leave the old filter in place till the fluid looks mostly clear of water..... then do one more drain and fill with the new filter at that point.....
Advice would be great on the steps to clean up my mess.
advice on terms for search or 'cheater links' to threads I could find or figure out?
thanks in advance from this gearheaded geek. good night y'all :thumbsup:
