OP
Mustangous
- Joined
- Oct 10, 2006
- Messages
- 225
nh_bota said:This is a very important point. Unlike the bagger for the 2230, the 2350 bagger does not use the 3 pt links. In fact, special brackets need to be bolted to the frame of the tractor (included with the bagger). The bagger then hangs on these brackets. The unit is heavy (200 lbs) and very difficult to maneuver into position and onto the brackets. There are very few similarities between the two bagging units, except for maybe the bags themselves. The 2350 unit is belt-driven compared to the 2230 unit which is shaft-driven.
I look at the 2350 bagger as a decent solution if you plan to keep it on there permanently. My recommendation would be to get the dealer to demonstrate how the bagger is installed and removed, then make your decision.
Hmm, Then would the better option be to try to order a 2230 bagger unit? From what you just said that might be a no brainer, as long as it would work. I would much prefer a shaft drive over a belt too. So what did they improve over the older model? maybe they did it this way to get the bagger closer to the tractor so if it does get too heavy it wont lift the front?
