purchasing a 30+ hp compact
/ purchasing a 30+ hp compact #1
rrostvet
Bismarck, ND
several
My first post, so things may be a little fuzzy. I grow native wildflower seed in 30 & 32 inch rows. Been doing this for years using a JD 955 and Yanmar 155D, (35 acres). Decided to go big or go back to day job ( wildlife biologist). My equipment and row spacing requires a tractor 50'' wide or less. Most posts are looking to spread the width out. I am looking to get the biggest narrow tractor with a cab (**** cold in ND) that I can get and still stay narrow, without getting into the big vineyard tractors. Any help would be appreciated.
/ purchasing a 30+ hp compact #2
Welcome to the forum.
The smallest tractor with a Cab that Kubota makes is a B3000. It is 53.7 inches wide according to their spec sheet. I don't know if it would be possible to set the wheels in on it or not to make it more narrow. The width measurement is usually on ag tires. They are supposed to have the new B50 series out this spring. I thought I heard about a 25hp B with a cab but I could be mistaken. You could also go with a B2920 and a aftermarket cab. It is 49'' wide. I am not sure if John Deere has any small cab tractors.
/ purchasing a 30+ hp compact #3
just getting the wind off of you, (soft cab) that you can take on/off can be a huge, if you want a heater, you can hook into the radiator hoses, and you can buy a radiator core, or hyd oil cooler, and place in cab, and use say a computer case fan, to blow warm air into the enclosure. but just getting that wind off you. is a big one, and layered clothing will hold out.
some tractors have 2 different widths, by turning rims inside out. (normally requires switching tires side to side to keep tread going in correct direction) one way is narrow, other way is wider.
not much help beyond above, been way to long since i went through all the manufacture websites and looked at specs.
last minute thought, i think agco one of there websites has a pretty good comparison setup. for a wide variety of manufactures of tractors. and gave fairly good details.
/ purchasing a 30+ hp compact #4
The blueberry vineyard down the road from me uses a Deere 3720 Cab with Ag tires set as narrow as possible. I think that will meet the width requirement. It's a nice set up. If I ever finish planting my orchard I'll go with the same setup.
/ purchasing a 30+ hp compact #5
I had a JD 955 with JDP cab. Very nice set up, but as you know, the JD's 33hp is rated at 3200 RPM. When you're in an aftermarket cab and there's no sound proofing built into the tractor, you have to have hearing protection and it's still loud.
I then went to a Kioti CK30 with Kioti comfort cab. It isn't factory, but it is built by Kioti for that tractor and is a very close second to factory. With R4's, it was just under 60" so it would be a little narrower than that with Ags and may have a narrow setting. It was a huge step up from the JD955 and even with 3 less hp (CK30 @ 2500 RMP), it would outwork the 955 by a very wide margin.
As mentioned, the smallest tractor with factory cab that I know of is the Kubota B3000 which just replaced the B3030 if you want to look for a used one. The BX and B series Kubotas seem to have very loud HST whinning noise and the noise level has been a complaint with the B3000/B3030 here on TBN (from both the engine and trans.).
Thanks for the sugestions! I have been looking at JD 4410s with after market cabs, the one with turfs is 53'', (a little wide) and one with R4s is 56'' wide, (way too wide). My 955 is 50'' but need more lifting power on the 3pt.
/ purchasing a 30+ hp compact #7
If you don't mind an aftermarket cab, something like Kioti's DS4110 is worth a look....over 2400lbs 24" behind the 3pt, and 49" minimum tread with Ags. Several companies offer decent looking cabs for them.
/ purchasing a 30+ hp compact #8
Not a compact but kubota makes the m series in a narrow format that comes in a cab and is only 48" wide
Engine Type (Kubota, liquid-cooled, diesel)E-CDIS, Direct Injection, 4-cylinder, natural engine, Tier IV
Displacement (cu. in.)203
Horsepower (net)63.5
Horsepower (PTO)56
Alternator Amps (80 amp optional)45
Transmission (fully synchronized)4-Speed
Speeds (forward/reverse)8F/8R 12F/12R w/ optional creep speed
Height (front of hood)46" (HOOD)
Overall Width48"
Overall Length136.4"
Crop Clearance (front axle)14.8"
Wheelbase80.7"
Dave
/ purchasing a 30+ hp compact #9
I could be wrong, but the number you're looking at is the width from inside to inside the tires. The overall width is 62" and I don't think you can get it down to 50", but who knows.
/ purchasing a 30+ hp compact #10
It's possible, but their spec sheet says front tread width minimum is 49 (no max listed) with Ags. For rears they list a Min of 47.6 and max of 59.1 with Ags. R4s would increase those numbers a touch.
/ purchasing a 30+ hp compact #11
Us vineyard guys just gave up and made the rows wider... :laughing:
I have a Kubota L3130 with R4 tires and an M7040 with R1 tires. For all intents and purposes, they're the same width (about an inch difference). But the L3130 sure "feels" more narrow. Kubota makes the M7040 in a 48" version for use in vineyards. You can get this with the CAB. I elected to make my row spacing 10 foot to keep from having to go with a narrow tractor that might not be able to do other jobs. Even at 10 feet it's gonna be tight, but I just cut a road with the box blade that's 7 foot and I didn't having any issues ripping down it, so the vines should be good.
Based on what you've posted so far the M7040 in 48" width would be the best choice - of course that's if cost is not a consideration. The base price with CAB is $44,372 - which isn't too bad. They also make a M6040 in the narrow version - but you can't get a CAB on that one.
Wow you guys are great! Hope I can return the favor in the future. Went down to the kubota dealer and measured a B3000 with R4s, (53"+) anyone know if ag tires make a difference? I assume a B3030 would be the same? The M series narrows, even high Hr. used exceed my max. of 20K.
/ purchasing a 30+ hp compact #13
"I assume a B3030 would be the same?"
Correct.
/ purchasing a 30+ hp compact #14
The R4 tires on my L3130 make it as wide as the M7040 with R1's - so yes, the AG tires make a difference. AG tires "generally" fit under the fenders while the R4's and turf tires will stick out.
/ purchasing a 30+ hp compact #15
I found a thread where someone said they have ags on a B3200. You could send him a Message to see if he knows the width of the Ag tires.
http://www.tractorbynet.com/forums/kubota-owning-operating/199545-12-4x16-ag-tires.html
/ purchasing a 30+ hp compact #16
The width of the B3000 - according to Kubota's spec page - is 53.7" minimum. Which indicated to me the AG's were on the tractor, but since the physical measurement of the R4's showed the same width I figured something had to be up. So I checked "Build My Kubota" and the R1 and R4 tires are the same on the B3000 - both are 12.4-16 in size. So going to the AG's in this instance isn't going to save you any width.
I found a B3030 with factor cab. It has 8.3-24 rear ag tires and is only 45" wide. I am unable to find any info on this tire option, everything I find says 12.4-16. Anybody heard of a 3030 with 24" rear wheels. Did Kubota make a narrow option for this tractor at some time?
/ purchasing a 30+ hp compact #18
/ purchasing a 30+ hp compact #19
I'm wondering what the B3030 is going to give you that the JD955 doesn't. It has a marginally better 3pt lift, less hp, 100lbs heavier etc. It's newer, but not a whole lot different. You'd be better off just sticking an after market cab on the 955 if it's still in good shape. The cab on the B3030 is notoriously loud anyway, so you don't loose anything that way. The only thing you'd be missing is AC. I'm sure some Kubota guys aren't going to like this, but that tractor's not powerful enough to run AC anyway. AC robs 5-7 engine hp, that doesn't leave you much to run a bush hog or other PTO driven implement.
My (used) JDP cab didn't have the door shocks anymore, so I used some foam pipe insulation on the door edges and bungy corded the door together open behind the tractor. Add a 12 volt fan and you're good to go.
If the JD 955 doesn't do what you need it to, I doubt a B3030 will either. In that case, if think you'll either have to go wider or find a good deal on an old vineyard tractor.
My 955 has served me well, except the 3 pt could use a little more lift for one implement. It is getting up there in hrs. 2000+ and the crops I grow are time sensitive. You are right that I would not be getting a gain in HP or wt., but much of my equipt. is custom built and many crops are perannual so going wider is not an option. Also do a lot of spraying (broadcast and hooded inrow) so a cab would keep the spray off me. Would like to go bigger but width is the constraint. My 955 is 50" wide and still get some crop damage when late season spraying.
2012 DRAGON 130BBL VAC TRAILER (A67714)
2012 DRAGON 130BBL...
2018 PETERBILT 579 (A67714)
2018 PETERBILT 579...
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2005 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2005 FORD F150...
2019 Ford F-450 Knapheide Service Truck (A66736)
2019 Ford F-450...
