Purchased 2305
/ Purchased 2305
I didn't think about driving over the mower. I may have to try that. I'm going to see if it will damage anything first. With my luck it will probably knock the tranny out /forums/images/graemlins/grin.gif
/ Purchased 2305 #42
rv,
I don't think the MMM for the 2305 is a drive-over design. I think you will find (my guess) that the lift links are not parallel to the ground, therefore, a forward or rearward position of an 1/8" or 1/4" might make all the difference to clear your gearbox. /forums/images/graemlins/tongue.gif
/ Purchased 2305 #43
Just FYI I was at my dealer today and they had a 2305 on their lot with a Woods BH6000 attached. I was in a hurry and didn't ask any questions, but they had it attached. /forums/images/graemlins/cool.gif
/ Purchased 2305 #44
The I Match hitch for my 2305 arrived yesterday and I have a question. I can not pull my garden trailer with the quick hitch attached. The tongue is too short. Does anyone know of a drawbar attachment for a I Match hitch? Or is there a tongue extension? Or any other ideas?
Thanks, this is my first post and not quite familiar with this forum yet.
/ Purchased 2305 #45
It's possible that your drawbar has multiple holes which allow it to be set out farther. Take a look.
Cliff
/ Purchased 2305
Jason L.
Can you give me your dealers name. I would like to call them and find out.
/ Purchased 2305 #48
I don't have a drawbar yet. I have been using the hitch under the pto. I guess what I can do is put a drawbar on the I Match hitch and some sort of drawbar lock so it wouldn't swivel. What I would really like is the swinging drawbar that attaches to the hitch under the pto and slides across the drawbar on the I Match. Then I could pick up my cargo trailer and drag it around. That is like the setup my dad had when I was on a farm a long time ago. Anyone done this? Or other solutions?
/ Purchased 2305 #49
</font><font color="blue" class="small">( I don't have a drawbar yet. I have been using the hitch under the pto.)</font>
That's the one I meant. There's a pin that holds that bar in place. You may find that there are multiple holes in that drawbar that lets you pull it out farther than it is now and replace the pin. It may not be ideal, but that would likely do the job unless I am misunderstanding your problem.
The 3pt drawbar is what you really need and they are cheap at about $25. The little lockers are available too.
The Easy Mover advertised on the attachments page (with an associated thread) when combined with a 3pt drawbar will give you a standard trailer hitch box which has it's advantages too.
Cliff
/ Purchased 2305 #50
Cliff
That's exactly what I was looking for. Thanks alot! It also helped me learn more about this forum and site. Hope I can help you out sometime down the road.
Bob
/ Purchased 2305
Back in business.
Put 4 hours on my 2305 today. It's working great. I'm very careful on the rough stuff now.
/ Purchased 2305 #52
Good to read you are back in business.
/ Purchased 2305 #54
Great news RVtech. There always seems to be bugs to work out in new models just sorry you lost some time with your new tractor. I am sure you will find you have bought a very capable tractor. My 2210 was a work horse. I need to find my before and after shots of my 5 acres. The contractor only dug the hole for the walkout and did the back fill. I did all the final grading with mine. I put in two gravel driveway (one 350 feet and one 300 feet). Built up a pad for the polebarn. Put in parking area of 50 by 100 feet and one by the cabin of 50 by 75. Bushhogged the lower 2 acres for a foot plot for deer and had to remove about 1 acre of mulitrose bushes from it. The tooth bar and bush hog did it all. I moved tons of rock and piled them near the pole barn to be used later for landscaping and building a rock retaining wall on one end of the cabin. Like I posted in another thread I had near 380 hours when I traded it last week and I would say 330 hours of the was loader, tiller, subsoiler and disking work.
Hope you get you backhoe soon.
Bob
/ Purchased 2305
So far I think just adjustments to move the radiator as far forward as possible. I don't think anything was gained. I'm waiting for some kind of a kit, possibly a brace to limit radiator movement. I'll be taking it easy until that is taken care of.
I called Jason L's dealer. They have a 2305 with a BH6000 installed. The salesman said they used a 2210 install kit and that it is the same. ??????
I'm missing something. /forums/images/graemlins/confused.gif
He confirmed a 200CX loader as well. There is no way the front bracket will fit. The side plates will not clear the loader lines either. I'm sure the lines could be bent to clear, but I don't want to do that if the correct brackets will clear. Woods told me the front and side brackets will be changed.
/ Purchased 2305 #56
FYI--if the loader is on when you are installing/removing the mower deck, you can use it to jack up the front end a little and slide the mower deck under. I've gotten in the habit of just taking the bucket off of the loader for better visibilty when mowing--just so I can use the loader to make the transition easier.
B8fish /forums/images/graemlins/wink.gif
/ Purchased 2305
Called Woods again after talking to Jason L's dealer. Woods said that dealer supplied the 2305 for bracket fitting. They were given a finished set of brackets for that 2305 plus 1 extra set for another. The manufactured brackets are still not available. There is now a part number, but it is not in their system yet. They still cannot give me a target time. They said at least 2 more weeks.
/ Purchased 2305 #58
Would the other dealer be willing to give you his spare set knowing the first set from Woods would go to him? I think Woods would agree that its the smart thing to do, And I don't think that dealer will be selling another that quick being he already has 1 in stock? They don't sell many backhoes this time of year in my area I'm not sure about yours?
Just food for thought.
Jim
/ Purchased 2305 #59
rvtech
Glad to hear you are back in business. I called my dealer and they included the bulletin in my reply email that John Deere issued on the radiator adjustments and hood adjustment. Apparently the hood can force the radiator into the fan if the latch is out of adjustment. Again, glad to see the dealer took care of it for you.
/ Purchased 2305 #60
rvtech
The beast is in!! My 2305 will be delivered on Friday (Oct 28). I will definitely watch out for the bumps in the road.
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
2015 Freightliner (A64119)
2015 Freightliner...
2014 CATERPILLAR 573C FELLER BUNCHER (A65053)
2014 CATERPILLAR...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
