Purchase Grand L Ten or M Series? Need help...
   / Purchase Grand L Ten or M Series? Need help...
All,
Thanks again. I'll respond with what I can below and will TRY to keep it to a minimum...I went to the Kubota dealer yesterday, but didn't make it before they'd closed. At least I got to look at several of the tractors, including an L3710 and an M4900 with cab.
cowboydoc, you've got the right idea here, in that I'm trying to capture a much as possible with 1 machine, rather than trying to afford several machines to do it all. I definitely can't afford a Cat III-sized tractor, so hopefully Cat II is sufficient. It sounds to me like the Grand L Series is a no-go on pulling a 15' mower, am I gathering that correctly from your info? (Remember - I'm pretty "green" to all of this!). If my application dictates that I *need* the larger sized tractor, I will forego HST, no problem. Is the PTO HP the limiter as far as the size mower you can pull? I may have to contact Rhino on this one and ask specifically about their wing and see what pops out. I'm still looking for "exactly" what implements can run on Cat II but not Cat I, and still wondering if it's just a matter of the "Size" of the implement.
Bird, it looks like I'm heading towards the bigger tractors now, so thanks for the words of encouragement. I drive stick-shift automobiles, so I"m used to clutching to change speeds/etc, just it's a lot more "heavy-duty" on a tractor. I'll definitely look into the powershift transmission.
glennmac, sorry if I didn't make clear what our intentions are with the property. It's probably because we're not really sure ourselves just yet. Disclaimer: what I say below is all subject to change, because I have no idea what I'm talking about. The 15 acres of woods we're planning on managing somewhat. It was logged 2 years ago and there are many piles of discarded lumber that will need to be removed for mulch/firewood. The tractor path through this small forest has totally grown over and many of the lumber piles are on it, so we'll need to clear this. Going forward we'll probably maintain this for firewood and the natural stand of hardwood trees contained in it, as well as keeping the path through the 15 acres clear of brush. The 15 acres of pasture will need to be mowed short-term and this is where we plan to begin our experimentation with tree farming. It should give us plenty of room to play with row spacings and let us figure out how long it takes certain trees to grow, how to care for them, etc... You are correct, we'll be renting out the other 60 acres to "traditional" vegetable farmers for now. Once we get a better handle on what we're doing and, if we still want to push forward with the tree farming nursery, the rentals will stop and we'll expand our plantings to the other 60 acres. Now, just LOOKING at this land we have, that seems like WAY too much land for my wife and myself to manage in a nursery operation, so we'll map out areas we use for tree farming (miuch of this may depend on soil samples to be done down the road) and the rest we'll start to grow up with "our own" trees, so the property will eventually become a nursery surrounded by its own trees. Here, we'll most likely begin by spading trees from our original 15-acre nursery experiment and plopping them all over the property where we want the forest to be. Of course, if this experiment doesn't work out, I'll either need to continue mowing/hauling lumber on the 15 + 15 acres or may try "traditional" vegetable farming beginning with a 20 acre field and progressing through the others. I wish I had a concrete plan, but I don't, so this is where we're currently heading.
cowboydoc, thanks for the reminder from my original post. The tractor will also need to do our plowing/tilling/dirt moving operations. There's a pretty big laneway down the property which I'm not sure should be plowed during the winter (I guess this will depend on whether I need to reach the back of the property or not!). Sounds like you're still leaning me to the bigger tractor! :) Thanks for the input, I'm attaching an aerial photo from New York State from a while back of the land so you can see the layout. I'll include a "doctored" version as well, hopefully this will make some things more "clear".
Von, I didn't get to talk to the dealer I went to yesterday (Saxby), but I'm making a note to look into Art White in Syracuse. I'm guessing I'll most likely go with Carver now, but if a local dealer can match him, they'll probably get my business. Thanks for the info.
John Miller III, Wow, that's pushing me even further to the realm of even bigger tractors. However, if the price is on par, I'll look into it. It seems that the tractors are priced $1,000 - $2,000 apart with identical features and just going up to the next size. This seems to apply to the L3710 - L4310 - L4610 - M4900 - M5700 - M6800, and may continue further. The jump from L3710 to M6800 looks to be ~$7,500. If only we weren't so strapped for cash from actually PURCHASING this place, I might be more easy to convince to jump up. I will bring this one up with the Mrs. :)
glennmac, I'm trying to do the research on what we'll need for tree farming before I buy anything...my research tells me I'll eventually need BOTH a tractor and skid steer, my finances tell me to stick with the tractor for now. It can do the "tree" things a skid steer can, just not as fast and fun as one. We're looking to grow the following: Sequoia Sempervirens, Sequoiadendron Giganteum, Metasequoia Glyptostroboides, Taxodium Distichum, Picea Pungens 'Glauca', Picea Abies, Pinus Nigra, Gingko Biloba, Quercus Alba, Quercus Rubra, Acer Saccarum, Acer Rubrum, Larix Laricina, Abies Concolor, Juglans Regia, Ulmus Americana and Castanea Dentata to start. Translated, that's Coast redwood, Giant Sequoia, Dawn Redwood, Bald-Cypress, Colorado Blue Spruce, Norway Spruce, Austrian Pine, Ginkgo Biloba, White Oak, Red Oak, Sugar Maple, Red Maple, Tamarack, White Fir, English Walnut, American Elm and American Chestnut. The elm and chestnut are "pet" projects aimed to help bring these trees back from the brink of extinction in the Eastern US.
Sorry so wordy...thanks for all help!
   / Purchase Grand L Ten or M Series? Need help... #22
Also from a Rochester suburb.
From a snow removal point of wiew, a rear mount snow blower would be my choice. Remember, that with a cab, you will need a remote to control the chute direction.
I have also been looking into a larger piece of land and have been casually looking into something larger than what I currently have. For the minor difference in price, I would opt for the M6800 over the M4900 M5700. From my research, the grand L will not be able to handle a decent size rotary cutter; whereas it would not be a problem for the M6800. M6800 also comes with extendable lower links which would certainly be an asset when hooking up some of those larger implements. The last time I checked Carver's site, the L4610 and the M4900 were similarly priced at about $31,000. And the M5700 and M6800 were both priced at $33,000. All of these with loader and cab (it is a nice cab). After this last summer...with the high heat and humidity...I wish that I had a cab. Unfortunately, in addition to the upgrade cost, the list price for a grand L cab (loaded) is about $7,500.
Good luck, Tom
   / Purchase Grand L Ten or M Series? Need help... #23
After reading your last post go out and buy the largest M-series you can afford. Just make sure to get a front end loader as well. Then down the road you can get a smaller tractor as needed.
Got one question about the trees your going to plant. Are they all going to grow ok in your area? Might want to talk with the local forester or extension service before buying a bunch of seedlings and then having them die the first hard winter. /w3tcompact/icons/frown.gif
Here is a link to some really good tree calculators. http://www.timberbuyer.net/toolbox.shtml
A really good forum to get questions about trees answered. http://www.forestryforum.com/cgi-bin/board/YaBB.pl
Five best places to buy trees off the net. <A HREF="http://forestry.about.com/library/weekly/aatp102201.htm
" target="_new">http://forestry.about.com/library/weekly/aatp102201.htm
</A>
good luck
Gordon
   / Purchase Grand L Ten or M Series? Need help... #24
<font color=blue>I'm still looking for "exactly" what implements can run on Cat II but not Cat I, and still wondering if it's just a matter of the "Size" of the implement</font color=blue>
Mike, you know the pins are larger on Cat II tractors and implements, and the pins on the lower link maybe farther apart, because the lower links on a Cat II tractor are bigger and will spread farther apart. Now as for which Cat II implements cannot be used on Cat I; probably none of them without changing the linkage pins at least, and then they may be too heavy for a Cat I tractor. But basically, you're right that Cat II implements are just bigger, heavier, and do the work faster. Generally speaking, you can use Cat I implements on a Cat II tractor by either using bushings on the pins, or in many cases Cat II tractors have ball joints in the lower links that have both Cat I and II holes, but you can't use Cat II implements on a Cat I tractor. As far as "exactly" which implements . . ., well, I don't know. It really is for the most part a matter of size.
Bird
   / Purchase Grand L Ten or M Series? Need help... #25
Mike,
There are two things that are going to limit you with implements primarily: 1. hp and 2. hydraulics. The last limiter is going to be weight. You need all three to run the higher end implements, esp. a tree spade or like a 15' batwing. Those same things will limit you from using cat. II impl. on a cat. I tractor. After reading this post I really think you will only be happy with a utility tractor and not a compact.
   / Purchase Grand L Ten or M Series? Need help... #26
We have only one overstock L4610 hst unit with loader and cab @ $28350. -http://carverequipment.com/cool_season_new.htm
Thanks,
Steve
   / Purchase Grand L Ten or M Series? Need help... #27
Mike: The 6800 is now available with hydro-shuttle, which allows clutchless shifting from forward to stop to reverse and back. I went through the same sorting out you did, and wound up with the 6800 for the reasons many of the others on this thread laid out for you. Don't know why Kubota's site doesn't reflect that option, which can give us the best of both worlds. The pricing increments are small for what you get in return. Regarding the loader, the self-levelling loader with detachable bucket gives a max. of flexibility for the future.
   / Purchase Grand L Ten or M Series? Need help... #28
mikeslavis
Made a trip to my dealers today, took the camera, pretty sure he had tree transplanter on the lot. The attached pics show a reconditioned mod. 500 3P mounted on a L4300DT. It is cat 1. Holes in attachment will allow cat2 pins. They stated they sell quite a few for the L series and the people love them. I learned a lot about tree transplanters today/w3tcompact/icons/wink.gif. Apparently a 20" ball mach. is for a 2" trunk dia. 30" ball for 3" trunk etc.
He mentioned one customeer using the 20" on a L3010, guy then upgrades to a L4610, then upgrades to the 30" transplanter. Dealer says they love it. The website for this transplanter is www.caretree.com.
If you don't find what you need there, I have about 20 pics and some brochures. Hope this helps.
regards
Mutt
   / Purchase Grand L Ten or M Series? Need help... #29
pic 2
   / Purchase Grand L Ten or M Series? Need help... #30
pic 3
Note: this set-up requires one pair of hyd. remotes
44052 (A55852)
44052 (A55852)
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2006 Trail King RGN 45' (A60460)
2006 Trail King...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
New Holland 308 Manure Spreader (A59814)
New Holland 308...
