Tires Punctures with filled R4's?
/ Punctures with filled R4's? #1
Not Retired Yet
Small farm in North Central Arkansas
2011 Kioti ck27hst
For anyone that has filled R4 tires and spend/spent a lot of time clearing land - did you ever puncture a tire? I really like the idea of added weight by filling tires, but am concerned about punctures and potential mess. What do you think?
/ Punctures with filled R4's? #2
I have beat the tar out of mine clearing my land and never had a leak, well worth the money to have them loaded!
/ Punctures with filled R4's? #3
I have mine filled with RimGuard, it's basically beet juice does not rust or corrode your wheels-no harm to the environment if you do do puncture. It's great for extra traction.
/ Punctures with filled R4's? #4
If you do get a puncture, be sure and tell who ever does the repair that it is on a filled tire, make sure they refill the tire when done.... Don't ask me how I found this out....
/ Punctures with filled R4's? #5
It is really hard to puncture an R4 in the woods or field. Metal could certainly puncture them but even that seems rare.
I've had no punctures in about six years of land clearing in wooded and rocky soil. I bump into buried metal not infrequently too as parts of the farm I work on was used as an old auto dump in years past. Never even a serious nick to the R4s over about 500 hours of seat time.
If it ever happens I intend to just put the puncture up top where the air is and use a reamer to jam one of those glue repair strips into the hole. Haven't done it yet but that is supposed to work. I dread the possiblity of needing to get a five hundred pound plus tire on and off a trailer without having use of my tractor to do it.
Thanks. I like the extra weight it gives but didn't know how puncture proof R4's are. My land is rough with broken/sharp limestone and the typical locust thorns and old barbed wire.
/ Punctures with filled R4's? #7
I believe your concern should be the number of plies (belts) instead of tire type, however I do think R4 are far better then turf tires for this application. Example, if I remember correctly Kioti R4 tires are 6 plies were Bobcat tractor R4 tires are 8 plies. In general the more plies the more punctures resistance the tire is. The ply type also affects puncture resistance. I really do not believe AG will buy you anymore puncture resistance then R4, it always seem to me punctures occur between the tread or in the sidewalls.
I did get one small wooden stick in my rear loaded tires. The stick didn't go through the plies but force itself between the top rubber (tread) layer and the top of the plies. This created a small bubble in the top of the tire between the tread. I used a pair of needle nose pliers to pull the stick out. I cleaned the hole then pushed in a plug (glue repair strip) to prevent dirt from entering the hole and grinding on the plies.
/ Punctures with filled R4's? #8
Regarding Ags vs R4, R4 are considerably more puncture resistant.
/ Punctures with filled R4's? #10
I assume you are looking to purchase a tractor (from your profile) with everything bundled and are trying to decide if loading the tires should be in the bundled? If so my vote is "yes" if you planning on using a FEL or ground engaging equipment like a bottom plow or box blade. If you search the forum for "Loading Tires" or "Tire Ballast" or "RimGuard" or "Washer Fluid Tires" you will find many discussions concerning this. I believe you will find the advantage outweighs the puncturing concern. Once you decide loaded tires are worth it then see if the dealer can get R4 tires with more plies and what the cost is. Also what does the dealer offer for liquid ballast? Many owners load their tires with windshield washer fluid (very low cost) or beet juice (RimGuard is one brand). Another option is Polyurethane Foam/Flat Fill but this is very expensive but maybe worth it in your situation. I believe the challenge with your question is 30 members could tell you they never had an issue and then the first day you use the tractor you puncture a tire. You just never know. If a tire puncture is a major concern and money is tight get factory R4 tires and load them with windshield washer fluid. There are DIY postings on the forum for this. If you go with this option you may want to purchase rear wheel weights for extra weight since windshield washer fluid is lighter then the other ballast options. Each of my tires has 600lbs of beet juice for a total of 1200lbs and my FEL can lift 2800lbs. This weight seems to work well for my tractor and FEL lift. I hope this helps.
Yes, you hit the nail on the head. That's what I'm aiming for and my concern. I've read a lot of threads on the loaded tires but couldn't remember any mention of punctures on R4's. I was curious how often R4's get punctured. Due to loader/boxblade/grapple work I plan on R4's.
/ Punctures with filled R4's? #12
I've done a lot of clearing work with mine including areas with locust the last couple of years. I've punctured a front tire but never one of my loaded rear R4's. I did have one episode where while backing up, a stick popped up inside of my rear tire and unfortunately caught and sheared the valve stem. Lost a significant amount of fluid from that episode. Refilled and never another problem.
/ Punctures with filled R4's? #14
Only back on mine.
/ Punctures with filled R4's? #15
I have similar worries for my filled tires. The Forest Service thinned behind my house 150-200' and left a lot of nice firewood for me. The problem is they cut the small stuff at an angle about 3-4 " high and that left punji type sticks all around. I would love to get the tractor back there to salvage the wood but I don't want to drive over those spikes.
/ Punctures with filled R4's? #16
I used rimguard filled R4s on my 2410 for a couple years with no problem even in the woods. As stated something like rebar might puncture the tire but they are pretty tough.
/ Punctures with filled R4's? #17
I do a lot of mowing and tilling of fields. One day while tilling a field I looked down to my left rear and saw strange piece of metal stuck to my tire and water leaking! It was an old gopher trap that the home owner had put out and fore got. Those sharp spikes will puncher R4's in a heart beat! So after repairing I had the tire shop add puncher seal made for liquid filled tires to back ones, ( I run just plain water) and I added "slime" to the front ones since I do a lot of berry bush mowing and clearing. I'm always pulling large thorns from the fronts.
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
2014 RAM VAV 2000 TRAILER MOUNTED VACUUM MACHINE (A59823)
2014 RAM VAV 2000...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
1408 (A57192)
1408 (A57192)
KJ K4525 45'x25' Double Garage Barn Shed (A60463)
KJ K4525 45'x25'...
