Pump size for log splitter
   / Pump size for log splitter #1
John123
I am building a log splitter and was wanting to know what is the biggest pump size i can use on a 6 1/2 HP motor?
Thanks!
   / Pump size for log splitter #2
Welcome to TBN:D
Look at these Calculators (on the left) and pick the Pumps & Motors one...should tell you all you need. Also these Calculators are very helpful.
Thanks, i was looking for something like that.... That will help alot. :)
   / Pump size for log splitter #4
The defined answer is, if you use a single stage hydraulic pump, it will be slow. A 7 HP engine running at 360o rpm, can run a .2 cu in pump, and produce 3.2 GPM. Using a 4 in cyl. Cycle will be 55.2 sec. Force applied will be about 18.5 ton
A two stage hydraulic pump will provide more GPM's because the first stage is pumping fluid at a lower pressure about 650 psi, and more GPM, At a set psi point, the pump will automatically shift to high pressure, 2500 psi and low GPM,s. Pressure determines power, and GPM determines speed of cyl operation.
https://www.surpluscenter.com/item.asp?UID=2009110606233380&item=9-7503-13&catname=hydraulic
The 13 GPM 2 stage pump, using the 6.5 HP engine. Force applied, 15 ton.
The cycle time of a two stage pump will vary based on the time the pump stays in the fast mode. If you are splitting very hard or stringy wood, the cycle time will slow down .
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
