Pump RPM recommendations
   / Pump RPM recommendations #1
James Eric
This is the pump that I own:
Specifications
Rated pressure: 2900psi.
Displacement .3759 cu. In/rev
Shaft: 1/2" keyed.
Ports: SAE 3/4-16 inlet: 9/16-18 outlet.
Rated RPM: 2000, Max RPM 4000
Part Number CB1A-F6SA
Are there any advantages or dis-advantages to running the pump at 2720 RPM in stead of 2000 RPM?
I am using it to power a Danco loader on a cub cadet 1250 tractor. My target lifting capacity is 400-500 pounds.
2040 RPM = 3.31 GPM
2720 RPM = 4.42 GPM
I plan to use 3/8" lines and run the PSI between 1200-1400.
What do you think?
Thanks,
James
   / Pump RPM recommendations #2
Pump speed will only change the max speed cylinders move. Does not affect the pressure (lift capacity).
Thanks. Maybe I should have been clearer with my questions.
1. Will the increased speed shorten the life of the pump?
2. Is the increased GPM flow worth the extra RPM's based on my target lifting goals?
James
   / Pump RPM recommendations #4
As long as you don't cavitate the pump inlet there would be very little change in life expectancy.
Recommended max flow rate for suction hoses is 4 feet per second. To get this flow rate you would need a minimum of 5/8" ID hose for the inlet.
3/8" hose is good for about 1.3 GPM at 4 FPS.
Roy
Thanks. That is very helpful. I will use a larger suction line.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
