pump rebuild
/ pump rebuild #1
alpha
Brimfield Ma
Jinma 354
I have a Jinma with a bad pump. it had metal shavings in it. it was'nt factory debured. so I cleaned it up debured it got it to spin easily but it dos'nt pump any oil. I cleaned the filter,flushed the tank made sure all the lines are clear and connected. The drive spline is good and the impellers turn. any ideas?
/ pump rebuild #2
Alpha, I'm sorry to tell you this, but most likely the pump is trashed. The metal filings probably galled the housing and ruined the seal between the impellers and the housing. No seal, no pumping oil. Without tight clearance, the pump cannot make enough vacuum to prime itself or if it did manage to pickup some oil, there would not be enough pressure to do any work.
The clearances inside the pump are very tight and it doesnt take much damage to ruin a hydraulic pump of any kind.
Make sure you get all of the shavings out of the sump before you install a new pump, or you will be doing this again. /forums/images/graemlins/frown.gif
Sorry for the bad news, hope I'm wrong.
Nailerguy
/ pump rebuild #3
I'm not familiar with your pump, don't even know if you are talking about an oil pump or a hydraulic pump, but are you priming it, filling with oil, before installing or hooking up lines and testing?
/ pump rebuild
yea sorry its a hyd. pump. Ive flushed the whole system with kerosene. tried priming the pump, still dead must have killed it? now that the system is cleaned filter too I will get a new pump and try that.
/ pump rebuild #5
/ pump rebuild #6
If the original pump was incorrectly manufactured, what makes you think a new one would be any better? Call the shops that rebuild hydraulic cylinders and pumps in your area. Many shops have a Blanchard grinder that they can use to restore the proper internal clearances in a pump. That would be my first choice especially with a foreign built pump.
Beats taking a chance on a new pump that may have the same internal defects as the original. If you're dead set on a new pump, try to get one that was manufactured recently. Maybe a later built part will have been put together correctly.
/ pump rebuild #7
alpha,
Maybe JohnS will speak up, he is very familiar with the Jinmas. I believe that I recall him saying the pump was very inexpensive. Here is his web site, it has lots of stuff about Jinmas. Johns Web Site
/ pump rebuild #8
I can't help but think you may have some other problem. It seems to me that unless there is an obvious visual flaw in the pump it should at least pump "some" oil; However, as someone suggested, if the pumps are inexpensive.......
/ pump rebuild #9
OH I forgot to mention that back when the CTOA was a better (read easier to find stuff) site there was a problem with a few different pump, mostly all was assoiated with the fact that someone disconnected the pump hose QD and that would blow the pump seals and dump hyd fluid into the oil. there was one or two otehr posts that had pump shaft had sheared off and was doing the same as you discribed. you said the key was ok, that was one issue I rembmber (note those are a few eyars worth of remembering so I don't have any details.)
Mark /forums/images/graemlins/ooo.gif
/ pump rebuild
well I got a new pump and all is well. /forums/images/graemlins/grin.gif
/ pump rebuild #11
Alpha,
Glad to hear you got a working tractor again...
Just curious, how much did the pump set you back? I would hate to think what one would cost for my Kubota!
I am wondering if parts prices are low enough [compared to the big three] to make that an advantage of owning a Jinma or other similar tractor. I mean an advantage that is not often, if ever, mentioned... /forums/images/graemlins/smile.gif
Thanks for reporting your success!
/ pump rebuild
pumps are cheap $120 not to bad. eh jinmas seem to be a good bang for the buck. I couldnt afford a big name tractor and get the 35hp fel and back hoe.
/ pump rebuild #13
Wow! That is pretty reasonable, Kubota wants $450 for the hydraulic pump on a B2400. I hate to think what they get for the newer series that uses an extra pump for the power steering! /forums/images/graemlins/shocked.gif
/ pump rebuild #14
Chinese tractors are just like Kubota and especially Kioti when they appeared on the farm scene. I remember 20 years ago a Kioti could be had for half the price of Kubota. Chinese tractor parts are cheap and easily repaired in the field. Quality control is just not up to the Big 3 or 4 but once you get them settled in their just as dependable. Most all PC parts are manufactured in China so don't think they can't build a farm tractor. They are just filling a void right now at the low end but are starting to send over higher quality in other CUT lines that they produce. They may just take over one of the Big 3 or 4 spots before we know it. No I don't sell Chinese tractors but I do own a farm and have used and owned tractors of most every brand.
Volvo EC220EL (A60462)
John Deere 450 (A64119)
John Deere 450...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
