charlessenf
OK, I'm real novice when it comes to these systems Never taken one apart, replaced a hose, etc.  I have added Hydraulic Fluid to the HF Tank.  I keep the thing indoors unless I am splitting wood.  I have had it for four years?   Maybe a couple more.
I noticed a wet spot on the basement floor and thought it the clear plastic hose (held on with a hose clamp) I tightened up the hose clamp and spread some absorbent stuff beneath where I park it - it did not appear to be leaking heavily thereafter.
This afternoon, after running a half a cord of wood through the splitter, I noticed the ground beneath the pump was WET enough to notice while standing about the splitter. To my untrained eye it appeared to be emanating from the top of the pump where the black hydraulic hose left the pump and connected to the valve.
Yet this seems less plausible to me seeing as this connection (and hose) has never been tinkered with since I've owned the machine (Purchased New). The machine is noisy and rattling is its normal state of operation - lots of vibration when running full out - but no where near enough to cause a hydraulic fitting to unscrew itself, right?
I've taken some pictures. Note how the top of the pump is really clean on the left side - I suspect this is from the (leaking) hydraulic oil effectively 'cleaning' the surface. Since the thing is leaking onto the leaves, wood chips and soil I'm not sure how much is leaking per (HR/MIN/Etc). I do intend to get a container under there next time out to see how much oil is leaking.
Meanwhile, If you have some experience with small hydraulic pumps / systems and are able to offer me some insights or diagnostic suggestions, I would appreciated same. Thank you for reading.
