Pump/Motor choice
   / Pump/Motor choice #1
Bncrshr77
Hello,
I started a thread in Customization about putting a Gas engine on a bush hog and a fella mentioned using hydraulics instead of pulleys...
I have an 18hp vertical shaft engine and plan on using a 4 or 5ft bush hog....
I have no clue about hydraulics and would like to know what size pump and motor I could run with the 18hp engine and power the bush hog?
Thanks,
--Tom--
   / Pump/Motor choice #2
Hydraulics are not near as efficient as belts and pulleys in this application plus the cost would be significantly higher.
formula for figuring input HP required for a hydraulic pump is:
HP = GPM x pressure in PSI / 1714 x pump efficiency.
   / Pump/Motor choice #3
I had a 42 in Dixie Chopper with 18 HP Kohler magnum engine, and I sometimes would cut for 8 hrs, The swing bld bush hog usually turn at a 1 : 1 ratio up 1 : 1.5, so if you reduce the engine rpm down to about 540, using pulleys and belts you will be doing the same thing as a 18 HP tractor pulling a 48 in bush hog.
I also have the Swisher 48 pull behind with a 11 HP Honda engine.
If you go hyd pump, and hyd motor, and if using a 20 hp engine, the efficiency of the pump and motor, will produce about 14.45 HP to the shaft on the motor.
   / Pump/Motor choice #4
2 pullys, (double belt) $40, two belts $15= $55.
or
one pump- $150, one tank=$75, One filter and filter assembly =$50, single spool valve $100 Hoses\fittings $150. Maybe $500-600 for hydraulics. May need cooler or 300lbs of tank and hydraulic fluid on board?
I am assuming of course you are pulling this with an ATV or tractor with no hydraulics or PTO.
200387 (A51247)
200387 (A51247)
2018 FORD EXPEDITION (A51406)
2018 FORD...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Mechanics Truck (A51692)
2019 Dodge Ram...
2014 Dodge 5500 4X4 Bucket Truck (A53473)
2014 Dodge 5500...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
