Pump in the new well
   / Pump in the new well #1
wjmst
Strongstown, PA
kubota bx2200
The drilling company came back on Friday and installed the pump into my new well. Here are some pictures of the process. The pump was set 10 feet from the bottom at 110ft.
Flickr: Photos from wjmst
Click on Well Pump
Here is a parts/price break-down.
1 – 10 gpm 1/2hp B Pump = $570
1 – DS 20 Tank = $165
1 – Tank Tee Assembly = $95
2 - ?? Male Adapters = $19
1 – ST Male adapter = $6
1 – Pitless adapter = $40
2 – Splice Kit = $10
3 – Cable Guard = $3
6 – Tape = $9
10 – Clamps = $9
145ft – 160PSI Pipe = $102
150ft – 12/3 sub wire = $113
20ft – ¾ Pipe = $9
4 – ¾ fittings = $4
Labor = $180 (about 2 hours)
Tax = $20.34
Total cost: = 1354.34
Total cost of entire well job $2317.34.
Not bad! Now, hopefully, the water clears up and I never run out. It is a little cloudy still. I suspect I will need some type of iron removal unit eventually as well.
Wes
   / Pump in the new well #2
try cleanmywater.com .... they'll test it for ya for free (then sell you what you need) I sent a sample to them and another to Texas A&M -- samples taken at the same time -- and the results were the same. Just thought it might be good to have a check & balance on their test. After all - they are in business to sell me something. (which they did)
30008 (A53424)
30008 (A53424)
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2018 DODGE RAM 3500 LARAMIE SERVICE TRUCK (A51406)
2018 DODGE RAM...
Toro 880 Procore (A55758)
Toro 880 Procore...
2006 TEREX FRONT DISCHARGE CONCRETE TRUCK (A54313)
2006 TEREX FRONT...
