pump flow rate versus implement requirement
   / pump flow rate versus implement requirement #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
If a hydraulic implement has a minimum flow requirement of 11 gpm, my tractors main pump is rated at 9.3 gpm and the power steering pump is rated at 2.8 gpm will the implement work? My tractor manual shows a total gpm flow rate of 12.1 gpm with both pumps added together. I assume that the steering pump cannot be figured into the implements requirement, is this correct?
   / pump flow rate versus implement requirement #2
That's correct , what type of implement are you wanting to use?
Was considering a loader mounted snowblower
   / pump flow rate versus implement requirement #5
Any hyd pump has a certain HP required to run it at about 95 % efficiency, and then you have to select a hyd motor that will develop the HP to do the work required, with an 85 % transfer efficiency. So the tractor engine, hyd pump and hyd motor have to be matched to make things work right.
If you know the GPM required for the snow blower, you can back figure the requirements for the pump, as to pressure and GPM. and at what speed.
As some have stated, you might not have enough HP or hyd GPM's to get the job done.
Manufactures are always over rating their products, for sales potential.
1994 Towable Sprayer (A51691)
1994 Towable...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
Deere 331G (A50123)
Deere 331G (A50123)
2013 Freightliner M2 106 Water Truck (A53117)
2013 Freightliner...
2019 Caterpillar 966M Articulated Wheel Loader (A51691)
2019 Caterpillar...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
