Pump direction
/ Pump direction #1
ch47dpilot
Enterprise Alabama
09 Kubota L3400
This maybe a question already asked but I couldn't find anything on it. When a pump is listed at CW or CCW do they base that on if your looking at the face(shaft end) or from the opposite end. The shaft i want to connect spins CW when I look at it, so I don't know if my pump will need to be a CW or CCW.
/ Pump direction #2
Rotation on a hyd pump is looking at the face of the pump, if your prime mover is CW then the pump you need is CCW (assuming it is direct coupled inline)
/ Pump direction #3
If they say that the pump is reversible, then it doesn't matter which way you connect it. Shaft to shaft connection will work like wdchyd said. You can vary the position of the pump to make it turn in the right direction by placing the pump side by side or off set, or shaft to shaft.
/ Pump direction #4
The only problem with this arrangement is the side load......most hyd pumps don't enough bearings for an overhung load......it wears out the pumps internals for premature failure.....(some are designed for it though)
If I had the choice I'd rather take the pump apart to reverse the rotation if needed and possible....that way it can be installed inline
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2007 Dodge Ram...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
UNUSED JCT 60" CLASS8-8000 LB CAP PALLET FORKS (A65055)
UNUSED JCT 60"...
48 Inch Bucket (A64553)
48 Inch Bucket...
