Pulverizer Use
/ Pulverizer Use #1
allpontiac
Bronze Member
NC
Ford/New Holland 1715
Just built a new house and the lawn was sewn in winter rye. This spring I will have to sew a permanent grass, probably fescue. I have a friend who got a pulverizer with a tractor he just bought and I can borrow the pulverizer. My question is: do you pulverize before you sew seed or after or both. Thanks in advance for your help - Lewis
/ Pulverizer Use #2
Allpontiac, I would do it before, Is your ground as level as you would like it? If so the pulverizer would loosen up the topsoil and provide a good surface for seeding,and you could also do some slight grading with it as well...You will obviously tear up any grass that is currently in place which can cause some eroding in the spring rains ...(maybe)
Another good item would be an aerator which is better for over seeding but you don't mention that , Maybe you could convince your friend he needs one and you could borrow it /forums/images/graemlins/grin.gif
Good Luck /forums/images/graemlins/smile.gif
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
BUYERS PREMIUM & PAYMENT TERMS (A59914)
BUYERS PREMIUM &...
UNUSED WOLVERINE HYD TRENCHER (A64281)
UNUSED WOLVERINE...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
1612 (A64280)
1612 (A64280)
