Pulverizer Questions
/ Pulverizer Questions #1
Charliebrn
Platinum Member
NW Ohio
Kubota BX-2360
Ok, I bit the bullet and bought a 4ft Gill Pulverizer for my BX. I want to re-do my backyard, which is mainly 7weeds and field grass where there is anything growing at all in our hard clay.
My question is whether anyone has any suggestions on how to best use it. Should I pull the tiller across the top first to break up whatever is growing, or sshould i just start hitting it with the pulverizer?
Any suggestions at all will be greatly appreciated. Thanks in advance...
/ Pulverizer Questions #2
No suggestions, but would you mind sharing how much one costs? I just picked up the brochure on them last weekend at the dealer's but all the salesman were too busy to get a price from. Looks like it would certainly do the job.
--Brad
/ Pulverizer Questions #3
I would use the pulerizer and leave the tiller parked. this way you won't need to refirm the soil.
/ Pulverizer Questions #4
I had a 2 acre area like that, and I wanted a nice dog training field. I borrowed a 6' pulverizer and 8' rake. First problem: neither the pulverizer nor rake would deal well with the sod (they clogged up). I tried tearing it up with the box blade scarifiers, but that didn't really get the job done. So my friend brought over an 8' disc, and I disced the heck out of the field. Then I raked off the remains of the grass and weeds. Then I worked it up with the pulverizer and raked the rocks out. Fertilized and seeded just before several days of gentle rain and everything came up great. Your experience may vary.
Brad,
I do believe the model I bought sells new for @$650 or so. I bought this one lightly used (in truth, it looks brand new) for $450. My intent is to sell it once I am finished with my yard. I think I should be able to get $400 back out of it this fall. We shall see.
Well, I don't have a disk, and don't know anybody that has one small enough to work with my tractor, either, so I hope that I could use the tiller just deep enough to remove the sod (weeds). I was afraid that the sod would be a problem, and you kind of confirmed this. Did you try angling the pulverizer forward or rearward?
What kind of grass did you plant? I'm in northern Ohio, and have large dogs that love to run...The areas that I had tri-plex take hold didn't hold up to the dogs well at all, so I'm going to have to try something new....something that has decent color, handles tough clay and temperatures and still deals with heavy use. Any ideas?
It's going to be interesting for sure.
/ Pulverizer Questions #7
You mean with the top link? Probably not. I had other options and it wasn't doing the job for me. Try it. Maybe your ground is different enough for it to work better.
I waited for the ground to thoroughly dry out before I even attempted to work it in this way. I was redistributing powder with the rake at the end. Of course, then you need water for the seed to take...
I planted the standard Great Lakes mix of Perrenial Rye, Creeping Red Fescue, and Kentucky Bluegrass. I had about 300 pounds left from a previous landscaping project. If I had to do it again I would consider using one of the turf-type tall fescue products (e.g. Rebels).
Start with a soil test. The pH is very important. My soil's pH was a little over 6, so I didn't need any lime. I did use starter fertilizer, but no mulch (I did run a partly full roller over the seed before the light rain started).
Try some of these links for more info.
<A target="_blank" HREF=http://ohioline.osu.edu/hyg-fact/4000/4011.html>Turfgrass Species Selection</A>
<A target="_blank" HREF=http://www.msu.edu/user/karcherd/turflinks/turflink.html>Ultimate Turfgrass Links Page</A>
/ Pulverizer Questions #8
My pulverizer works well in areas that have thin vetitation. moderate or more then the tiller is faster followed buy the pulverizer to level and firm the ground. I have a landpride 6' model and it can stop my 4400 if I get it too far in the ground.
/ Pulverizer Questions #9
From what I have read on lawnsite, it's a good idea to kill the weeds with Roundup before you pulverize/till or whatever. Spray 'round up, wait a week, and water the heck out of it. When the new weeds start emerging spray with roundup again. Wait two weeks before you pulverize and then plant grass. Otherwise you risk having a lot of weeds coming back up in your grass. Just a thought.
Mike
/ Pulverizer Questions #10
The people who sell these products certainly do tell you to do this. In some areas it might be important. In my case I did not care about a few weeds, but did not wind up with an objectionable number.
/ Pulverizer Questions #11
Charliebrn,
I have to agree with DDT, seem best ( at least for me) to till up the the soil: at least the sod part, then use the gill to smooth and pulverize. I found otherwise the Gill just clogs up on grass.
Nick
The road less traveled is pretty rough too! /w3tcompact/icons/grin.gif
/ Pulverizer Questions #12
Well, I have tried all methods just about known to man and beast and screwed up w/a lot of them as well. The method that I use is to till in your existing weeds, grass ect ect and the use your landscape rake to remove these from the tilled area. You may then use your pulverizer and as the soil reaches your liking then extend your top link and raise the lift on your tractor a bit for a not so agressive action of your pulverizer.
2022 WESTERNSTAR DAYCAB 4700 CONCRETE MIXER TRUCK (A67714)
2022 WESTERNSTAR...
2007 Chevrolet C7500 Auto Crane 8406H 8,400 lb. Crane Mechanics Truck (A66736)
2007 Chevrolet...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
IRANCH WOOD GRAB ATTACHMENT (A67714)
IRANCH WOOD GRAB...
INGERSOLL RAND VR90B TELESCOPIC FORKLIFT (A65056)
INGERSOLL RAND...
